Usb Tuner IT9135 Alfatech
Hi all,
Same problem here, When I connect an 048d:9135 usb dvb-t tuner, my dmesg shows this:
usb 1-2: new high-speed USB device number 3 using ehci-brcm
usb 1-2: dvb_usb_af9035: prechip_version=83 chip_version=02 chip_type=9135
usb 1-2: bh_dvb_usb_v2: found a 'ITE 9135 Generic' in cold state
usb 1-2: bh_dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
usb 1-2: dvb_usb_af9035: firmware version=3.39.1.0
usb 1-2: bh_dvb_usb_v2: found a 'ITE 9135 Generic' in warm state
usb 1-2: bh_dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (ITE 9135 Generic)
i2c i2c-3: af9033: firmware version: LINK=0.0.0.0 OFDM=3.9.1.0
usb 1-2: DVB: registering adapter 1 frontend 0 (Afatech AF9033 (DVB-T))...
i2c i2c-3: tuner_it913x: ITE Tech IT913X successfully attached
IR keymap rc-it913x-v1 not found
Registered IR keymap rc-empty
input: ITE 9135 Generic as /devices/platform/ehci-brcm.0/usb1/1-2/bh-rc/rc0/input2
rc0: ITE 9135 Generic as /devices/platform/ehci-brcm.0/usb1/1-2/bh-rc/rc0
usb 1-2: bh_dvb_usb_v2: schedule remote query interval to 500 msecs
usb 1-2: bh_dvb_usb_v2: 'ITE 9135 Generic' successfully initialized and connected
usb 1-2: USB disconnect, device number 3
usb 1-2: bh_dvb_usb_v2: 'ITE 9135 Generic' successfully deinitialized and disconnected
usb 1-1: new high-speed USB device number 4 using ehci-brcm
usb 1-1: dvb_usb_af9035: prechip_version=83 chip_version=02 chip_type=9135
usb 1-1: bh_dvb_usb_v2: found a 'ITE 9135 Generic' in cold state
usb 1-1: bh_dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
usb 1-1: dvb_usb_af9035: firmware version=3.39.1.0
usb 1-1: bh_dvb_usb_v2: found a 'ITE 9135 Generic' in warm state
usb 1-1: bh_dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
usb 1-1: DVB: registering adapter 1 frontend 0 (Afatech AF9033 (DVB-T))...
input: ITE 9135 Generic as /devices/platform/ehci-brcm.0/usb1/1-1/bh-rc/rc0/input3
rc0: ITE 9135 Generic as /devices/platform/ehci-brcm.0/usb1/1-1/bh-rc/rc0
usb 1-1: bh_dvb_usb_v2: schedule remote query interval to 500 msecs
usb 1-1: bh_dvb_usb_v2: 'ITE 9135 Generic' successfully initialized and connected
But when I try to use the tuner I get a Tuner B: Dummy Tuner (unsupported). If I issue a cat /proc/bus/nimsockets I get:
NIM Socket 0:
Type: DVB-S2
Name: BCM7362 DVB-S2 NIM (internal)
Frontend_Device: 0
I am using a Vu+ Zero, running BH 2.1.7.01 (just upgraded this afternoon). Do I have something to try? Or is it better to buy another dvb-t usb tuner (chipset).
Thanks beforehand
It's me again,
this is my lsmod:
Module Size Used by Tainted: P
ext2 56975 0
tuner_it913x 4980 1
af9033 24726 1
dvb_usb_af9035 14329 0
bh_dvb_usb_v2 14345 1 dvb_usb_af9035
bh_dvb_core 88115 1 bh_dvb_usb_v2
bh_rc_core 19111 3 dvb_usb_af9035,bh_dvb_usb_v2
fpga_directc 493 0
brcmfb 1590 3
dvb_bcm7362 6641133 15 brcmfb
procmk 1668 1 dvb_bcm7362
ipv6 326329 12 [permanent]
Hi all,
NIM Socket 0:
Type: DVB-S2
Frontend_Device: 0
Thanks beforehand
Have you rebooted your box afeter tuner plug?
Hi all,
Sorry to trouble you, but...I have same problem with my Vu Solo2 from BH 2.1.0.1. It means with this image everything is OK, DVB -T dongle is working, I see it in tuners list. However starting from BH 2.1.1. up to BH 2.1.7.01(after all upgrades of BH 2.1.7. and reboot and etc.) my DVB-T dongle is detected and connected, but I don't see it in tuner list and in manual scan to. I have made recommended debug scripts.
I would appreciate if somebody will help me.
Thanks for Your effort solving this issue.
i have similar dvbt tuner and i have Vu+ solo se V2 and 2.1.7, but i cant see the tuner, but seem found ....
lsmod :
root@vusolose:~# lsmod
brcmfb 1590 4
dvb_bcm7241 1285203 26 brcmfb
dvb_base 5179453 181 dvb_bcm7241
bcm_event 2821 5 dvb_bcm7241
procmk 1668 2 dvb_bcm7241,bcm_event
ext2 56975 0
tuner_it913x 4980 1
af9033 24726 1
root@vusolose:~#
cat /proc/bus/input/devices :
I: Bus=0003 Vendor=048d Product=9135 Version=0200
N: Name="ITE 9135 Generic"
P: Phys=usb-ehci_hcd-1/ir0
S: Sysfs=/devices/platform/ehci-brcm.1/usb2/2-1/bh-rc/rc0/input0
U: Uniq=
H: Handlers=event0
B: PROP=0
B: EV=100013
B: KEY=1000000 0 0 0 0
B: MSC=10
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="dreambox advanced remote control (native)"
P: Phys=
S: Sysfs=/devices/virtual/input/input1
U: Uniq=
H: Handlers=mouse0 event1
B: PROP=0
B: EV=b
B: KEY=108fc312 2040041 0 0 30000 0 18000 4190 c01 1e3fd0 0 33fffff d3ff7ffc
B: ABS=3
lsmod :
brcmfb 1590 4
ext2 56975 0
tuner_it913x 4980 1
af9033 24726 1
root@vusolose:~#
U: Uniq=
H: Handlers=event0
B: PROP=0
B: EV=100013
B: MSC=10
P: Phys=
U: Uniq=
B: PROP=0
B: EV=b
B: ABS=3
Have you made all online updates avaiable for 2.1.7 image series?
I mean I want see a channel of dvb t on my tv and see a channel of dvb s/s2 on my phone by streaming in a same time. Is it possible too?
Thanks to reply
New BH 3.0.1 for ULTIMO not working with tuner USB OMEGA T900 DVB-T (Chip IT9135 BDA) . An earlier version 2.0.9 everything worked OK. What could be the cause ? I reported this problem in the forum.
I attach again files dmesg , maybe it will help solve the problem. Can someone tell me how I can solve that, or maybe it is a matter of drivers for new BH?
Have you managed to establish where there is a problem with the driver for IT9135? I checked the latest update BH and USB tuner is not visible in the configuration ultimo.
Yesterday I checked for the latest version and further tuner USB does not work. Are there any new news about the driver for IT9135 for new BH?
