Usb Tuner IT9135 Alfatech
I think your tv is connected to the decoder with a T connector. Do you confirm this? Try connecting directly to the usb key removing as much cable as connectors as you can. For this test the key has to be connecte directly to the aerial.
Yes, exactly. The tv tuner is connected with T connector.
I will try connect directly to Vu.
You should also try to use an external powered hub USB to minimize the power problem who impact performances of device who doesen't catch enough power from USB port
Ok I have new information. I do not see better effect when tv usb is connected directly to Vu+ Duo usb port.
https://www.dropbox.com/s/5k6w6ch8j3c2z6y/2013-11-26%2019.28.19.jpg
https://www.dropbox.com/s/54j0loi89uiqcsi/2013-11-26%2019.30.40.mp4
But I notice something interesting. On Freq 578000 band 8MHz (signal between 0-87%) is not possible to watch any channel on this frequency. Because all time is pixelation effect.
On 506000 (4-99%) and 490000 (4-99%) I can watching long time, but sometimes also is the pixelation effect.
Example, when on 506000 freq i have pixelation, that I had changed on channel from 490000 freq, and quick back to channel from 506000, than the pixelation effect will pass for a while.
Sorry for my weak english :(
Help!!!!
Restart the deco , once restarted, turn off and disconnect from behind, introduce the DVBT USB Dongle , I turn back , I go to menu - channel scan goes
Tuner B : dummy turner (not supported )
Information:
Thanks,
Hi colegues, I still have same problem with BH 2.1.7
Tuner B : Dummy Tuner (not supported )
on VU PLUS Solo SE
Is there some solution, maybe you can post updated drivers or plugin?
