Hi angelofsky1980, have you looked anything about CDTDIGDUAL V2 support?? Sorry if I'm annoying but I bought it in December and I can't use it yet. If the best option is buy another stick, please let me know.I'm in my TODO list your problem ....
Thanks angelofsky1980, but don't appear. I attach dmesg. Is it the debug file or need that I send any other telnet command?
This is the website of stick : http://www.conceptronic.net/product.php?id=324&linkid=296&ttype=0&ttype=3&ttype=0&ttype=3&ttype=0
There are only windows drivers. On the stick I can read this :
CONCEPTRONIC
Product code : CTVDIGDUAL
C08-097
VERSION 2.0
After a reboot, here are the files :
ls -l /lib/modules/3.3.6-1.2/kernel/drivers/media/usb/dvb-usb-v2/
root@vusolo2:~# ls -l /lib/modules/3.3.6-1.2/kernel/drivers/media/usb/dvb-usb-v2/
-rw-r--r-- 1 root root 30104 Apr 12 19:01 dvb-usb-af9015.ko
-rw-r--r-- 1 root root 19612 Apr 12 19:01 dvb-usb-af9035.ko
-rw-r--r-- 1 root root 23340 Apr 12 19:01 dvb-usb-anysee.ko
-rw-r--r-- 1 root root 7492 Apr 12 19:01 dvb-usb-au6610.ko
-rw-r--r-- 1 root root 18304 Apr 12 19:01 dvb-usb-az6007.ko
-rw-r--r-- 1 root root 8688 Apr 12 19:01 dvb-usb-ce6230.ko
-rw-r--r-- 1 root root 9932 Apr 12 19:01 dvb-usb-ec168.ko
-rw-r--r-- 1 root root 7536 Apr 12 19:01 dvb-usb-gl861.ko
-rw------- 1 root root 257503 May 1 12:14 dvb-usb-it913x.ko
-rw-r--r-- 1 root root 29084 Apr 12 19:01 dvb-usb-lmedm04.ko
-rw-r--r-- 1 root root 77116 Apr 12 19:01 dvb-usb-mxl111sf.ko
-rw-r--r-- 1 root root 23468 Apr 12 19:01 dvb-usb-rtl28xxu.ko
-rw-r--r-- 1 root root 4512 Apr 12 19:01 dvb_usb_cypress_firmwae.ko
-rw-r--r-- 1 root root 23728 Apr 12 19:01 dvb_usb_v2.ko
-rw-r--r-- 1 root root 11880 Mar 16 09:43 mxl111sf-demod.ko
-rw-r--r-- 1 root root 9888 Apr 12 19:01 mxl111sf-tuner.ko
depmod ; depmod.26
modprobe dvb_usb_it913x
dmesg attached
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Custom Black Hole build
usbcore: registered new interface driver dvb_usb_it913x
it913x: Chip Version=01 Chip Type=9135
it913x: Remote propriety (raw) mode
it913x: Dual mode=3 Tuner Type=38
usb 2-1: dvb_usb_v2: found a 'Digital Dual TV Receiver CTVDIGDUAL_V2' in cold state
usb 2-1: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9137-01.fw'
it913x: FRM Starting Firmware Download
it913x: FRM Firmware Download Completed - Resetting Device
it913x: Firmware Version 204147968
usb 2-1: dvb_usb_v2: found a 'Digital Dual TV Receiver CTVDIGDUAL_V2' in warm state
usb 2-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (Digital Dual TV Receiver CTVDIGDUAL_V2)
it913x-fe: ADF table value :00
it913x-fe: Crystal Frequency :12000000 Adc Frequency :20250000 ADC X2: 00
it913x-fe: Tuner LNA type :38
usb 2-1: DVB: registering adapter 1 frontend 0 (Digital Dual TV Receiver CTVDIGDUAL_V2_1)...
usb 2-1: DVB: registering adapter 2 frontend 0 (Digital Dual TV Receiver CTVDIGDUAL_V2_2)...
usb 2-1: dvb_usb_v2: 'Digital Dual TV Receiver CTVDIGDUAL_V2' successfully initialized and connected
Yes!!!! After reboot it has appeared. No, it's searching channels. When finish I post results. You are great, my friend.
Enviado desde mi HTC Desire X usando Tapatalk 2
All is working fine. By the moment only one tuner. Will I need to do same steps in every new firmware releases?
Enviado desde mi Transformer TF101 usando Tapatalk 2
I can configure two satellite tuners and two terrestrial tuners.How many DVB-T tuners can you configure via Enigma2?
The updated driver will be avaiable in the next BH without repeating these steps.
I was hoping for af driver update for my Newsky DVB-T DAB FM USB RTL2832U / E4000 Stick my vu+ duo and solo2 finds it but dosent scan anything , and a driver update for my haupage win tv mini hd stick it only shows signal between 5 and 8 % no agc or ber, no problems with alfa af9035
https://www.dropbox.com/sh/g5llxxgt9t3v4l8/SMMyiIKOaa
https://www.dropbox.com/sh/qiewqni2gyzmf7g/cwaEOrMfLw
