We need debug file (http://www.vuplus-community.net/boa...images-debug-script-per-le-immagini-bh.21512/)I'm installed 2.1.0 and tuner works. And on fresh installed 2.1.7 don't work.
DO ALL ONLINE UPDATES FOR 2.1.7 IMAGE.It's here:
Code:https://www.dropbox.com/s/303615y0u176rf3/dvb_debug.txt?dl=0
NoIt's not possible to copy something from 2.1.0 to 2.1.7 (ex. drivers)?
I'll investigateDebug file after image update:
Code:https://www.dropbox.com/s/rjodizjhltym7vj/dvb_debug_2.txt?dl=0
Probably into rear ports the device cannot take all the power needed to work correctly and into the front port can get it.My USB tuner works fine only on front usb port. None of rear ports detects the usb tuner.
What's is difference between the front port and the rear ones? (SOLO 2)
By the way, My HDD & Wi-Fi work fine with rear ports.
On my case also don't work on front usb.I'm installed 2.1.0 and tuner works. And on fresh installed 2.1.7 don't work.
Have you updated online the 2.1.7 image?On my case also don't work on front usb.
