Usb Tuner IT9135 Alfatech
Ok am successful :)
It seems angelofsky1980 firmware uploaded it9135_01.fw was not extracted ok or was corrupted.
After i replaced with correct one usb tuner started working and channels started scanning.
What i recommend is extract all firmwares provided here into firmware folder and make chmod 644 reboot and enjoy a working tuner :)
I have to report am seeing problems in dmesg output.
1. usb 1-2: dvb_usbv2: pid_filter() failed=-2024836320
2. dmxdev: buffer overflow
By the way someone tell me where to post for support because there are 2 9135 threads. Thanks :)
Bugs:
1.You can record from satellite and after finish it can record from terrestrial if you have timer set but when is the opposite e.g.
you are recording terrestrial channel and finishes anything next you have on satellite channel timer to be recorded wont.
2.When you record terrestrial channel you cant open satellite channel, comes up black screen.
Please have a look at it and i hope if possible we have a fix.
Thank you in advance.
Hi, I have received my VU Solo2 and a DVB-T usb stick Conceptronic CTVDIGDUAL 2.0. My box doesn't detect the tuner, even I install the drivers included in this post but no luck. I attach the cat /proc/bus/usb/devices output and dmesg
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1b80 ProdID=e410 Rev= 2.00
S: Manufacturer=ITE Technologies, Inc.
S: Product=DVB-T TV Stick
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Any news about my stick? I understand that my stick is not supported yet by linux systems. Is it true?
Enviado desde mi Transformer TF101 usando Tapatalk 2
The chipset is already supported. We need time to analyze the dmesg and other output you posted.
Your dmesg don't say nothing interesting about tour pen.
Tour should hotplug it.
However i think in next bh it may be supported.
Inviato dal mio U8800Pro con Tapatalk 2
Hi
When you file your 9135 driver put the tuner Watching a channel will be zero, and must signal one minute after you restart. Where do you think the problem is
Hi, with the new image BH 2.0.0, my Conceptronic CTVDIGDUAL is not detected, like with old 1.7.9 firmware. Do I buy another stick?
Telnet response to cat /proc/bus/usb/devices
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
I also attach my dmesg.
Can we do anything?
Can we do anything?
I will look into source code drivers ....
Not for me. Angelofsky1980, when will you have a look to the drivers. I say that because I need DTT channels in the box and would buy other stick if there is no solution for this one.
Sorry.
Sorry.
I'm in my TODO list your problem ....
