Adeguamento ricevitori VU per iptv
1. fai tutti gli update
2. riavvia ...
3 da telnet: df -h
4. sempre da telnet, enigma2 e avvia xbmc
posta qui il contenuto
2. riavvia ...
3 da telnet: df -h
Ok tra un po' ci provo e ti dico e che sinceramente da telnet che non so come dare quel comando... del punto 3 e neppure del punto 4.
Sto usando putty un programmino passato da un amico per collegarmi con il pannello telnet al decoder,
Dopo aver messo root come login adesso do i tuoi comandi e vediamo, aggiornamenti dell'immagine black hole generale non c'e' ne erano.
record: 0
[add callback]
allocate channel.. 189c:fbff
allocate Channel: res -7
RECORD service event 11
[TIMER] record event 3
[TIMER] 'prepare' failed: error -7
[TIMER] backoff: retry in 10 seconds
stop recording!
(was not recording)
[TIMER] record event 5
[TIMER] record event 1
[remove callback]
[TIMER] prepare failed
[timer.py] next activation: 1445893566 (in 9991 ms)
action -> MsgBoxActions ok
child has terminated
pipes closed
pipes closed
[ePopen] command: route -n | grep eth0
pipes closed
poll: unhandled POLLERR/HUP/NVAL for fd 63(16)
poll: unhandled POLLERR/HUP/NVAL for fd 65(16)
poll: unhandled POLLERR/HUP/NVAL for fd 67(17)
pipes closed
0.0.0.0
169.254
192.168
nameservers: [[192, 168, 0, 1]]
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': True}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [192, 168, 0, 6], 'up': True, 'mac': '00:1d:ec:09:ab:d3', 'dhcp': True, 'bcast': [192, 168, 0, 255], 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 0, 1]}}
AT plugin not found
SerienRecorder plugin not found
ER plugin not found
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
[OpenWebif] no plugins to load
[OpenWebif] failed to listen on Port 80
It's now Mon Oct 26 22:06:06 2015
[TIMER] activating state 1
begin_date: 20151026 2155
service_name: Fox
name: Salem - 1^TV
description:
[TIMER] Filename calculated as: '/hdd/movie/20151026 2155
recording service: <enigma.eServiceReference; proxy of <Swig Object of type 'eServiceReference *' at 0x19c9068> >
record: 0
[add callback]
[TIMER] backoff: retry in 20 seconds
stop recording!
(was not recording)
[remove callback]
[timer.py] next activation: 1445893586 (in 19994 ms)
recording service: 1:0:1:1FBA:189C:FBFF:820000:0:0:0:
record: 0
record: 0
recording service: 1:0:1:5A3:320:FBFF:820000:0:0:0:
record: 0
record: 0
record: 0
recording service: 1:0:1:2:1770:110:820000:0:0:0:
record: 0
record: 0
record: 0
Bug: unknown Conflict!
ignore timer conflict
[Timer] Record <RecordTimer.RecordTimerEntry object at 0x19c7230>
ProcessRepeated
localrepeatedbegindate: Wed Oct 28 23:30:00 2015
localbegin: Wed Oct 28 23:30:00 2015
localend: Thu Oct 29 01:30:00 2015
localnow: Mon Oct 26 22:05:47 2015
Day: 2
ProcessRepeated result
It's now Mon Oct 26 22:05:46 2015
[timer.py] next activation: 1445893551 (in 4537 ms)
[timer.py] next activation: 1445893646 (in 99193 ms)
[browser] browser start
Looking for embedded skin
[glClass] ANIMATION #0 selected
[CrossEPG_Auto] AutoStart Enabled
[CrossEPG_Loader] patch epgcache.load() found
[CrossEPG_Auto] Schedule Enabled at Mon Oct 26 22:05:47 2015
[CrossEPG_Auto] Time set to Tue Oct 27 04:00:00 2015 (now=Mon Oct 26 22:05:47 2015)
[AutoShutDown] start....
port changed to DVI
mode changed to 1080p
default ('1080p', 'Predefinito')
preferedmodes ['720p', '1080i', '576p', '480p', '576i', '480i', ('1080p', 'Predefinito')]
[EPGC] setCacheFile read/write epg data from/to '/media/usb/epg.dat'
[EPGC] time updated.. start EPG Mainloop
before: 1
after: 1
not showing fine-tuning wizard, config variable doesn't exist
showtestcard is false
setValue 90
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
Setvolume: 90 90 (raw)
Setvolume: 7 7 (-1db)
allocating new converter!
reused converter!
Allora aggiornamenti in merito ho visto che praticamente mi dava uno stretch a 1920x1080 quando lanciavo XBMC sono andato in impostazioni e messo si HDMI ma risoluzione 720p non 1080i ; perche' correggetemi se sbaglio ma xbmc lavora in 720p o erro?
Adesso infatti l'IPTV che sto testando sembra funzionare.... premesso che il mio amico me l'ha fatta inserire tramite questo stringa: wget -O /etc/enigma2/iptv.sh
azz ultime parole famose si e' bloccato il dec di nuovo....appena chiuso il pannello telnet come mai? Devo nuovamente spegnere e riaccendere da pulsante il dec.
fatti un backup delle tue cose !
da telnet, ferma enigma2 con il comando: init 4
con filezilla, dcce2, quello che hai, vai in etc/enigma2
trova il file in questione.
Aprilo con un editor linux compatibile, notepaad++ ultredit, quello che hai.
cancellane il contenuto, incolla:
<?xml version="1.0" ?>
<timers>
</timers>
salva
riavvia enigma2 sempre da telnet con: init 3
<timers>
</timers>
salva
Questa operazione mi fa perdere solo i timer PRE-SETTATI? Posso ripristinarli dopo?
Ma scusami un dettaglio, ma quando parte XBMC non parte con la stessa grafica o impostazione del pc? Per poterlo sfruttare per vedere musica, video ecc.ec.c.?
L'iptv inserita devo levarla durante queste operazioni?
non casualmente ti ho indicato di farti PRIMA un backup, non si sa mai ...
per il resto,io ho settato 1080i
Appena fatto come dici tu e mi dice il file TIMER.XML e' danneggiato e non puo' essere caricato.
E mi resta nella schermata iniziale di BLACKHOLE BLU con scritto starting gui...cambio canale e si vede, quando si avvia il dec se prima lo avevo lasciato su un canale dell'iptv, non parte resta nella pagina blu citata prima, devo cambiare canale per farlo vedere e' normale?
DEMUX_STOP - audio - ok
AUDIO_CONTINUE - ok
DEMUX_STOP - ttx - ok
cleaning up
TuxTxt cache cleared
start release channel timer
release cached channel (timer timeout)
[eDVBCAService] remove channel 0x2b086f8
[eDVBLocalTimerHandler] remove channel 0x2b086f8
[eEPGCache] remove channel 0x2b086f8
stop release channel timer
BlackHoleapi: popclose,
XBMC Display Resolution : 1920x1080, Stratch : 1
close frontend 2[EPGC
vedo se trovo un file iptv free e ti so dire
Provato, non è normale
cmq. non ho capito bene che vuoi dire ..
prima parli di kodi, poi passi alla iptv ...
spiega...
Allora io ho provato come dici tu, e senza inserire nessuna iptv si blocca il decoder appena lancio da plugin XBMC, devo spegnere e riaccendere il decoder.
Mentre ieri sera un mio amico mi ha passato una sua iptv e me l'ha fatta inserire tramite telnet e si e' caricata subito dentro il decoder e si vedeva la lista dei canali e tutto.
Se pero' provavo a lanciare XBMC si bloccava sempre e non partiva.
Facendo il cambio da 1080i a 720p e seguendo il procedimento con il pannello telnet che mi dicevi tu: enigma2 e poi avviavo xbmc, mi si avviava l'iptv direttamente senza problema; appena chiudevo telnet si ribloccava il dec.
Quindi questa cosa non capivo e ad ora non capisco. Adesso sul decoder ho tolto l'iptv e sono al punto di prima. Non dovrebbe partire lo stesso XBMC senza iptv inserita e mostrando un suo pannello di gestione?
Facciamo una cosa alla volte, se no non se ne esce.
Lascia perdere la IPTV che a noi NON interessa.
enigma2
poi avvii xbmc ...
Ecco fatto proprio ora, partiamo da qui senza iptv per capire come mai non va:
N.B. Ora che l'ho spento e riacceso dal pulsante on/off resta fermo alla scherma STARTING GUI...devo premere il tasto cambio canale per sbloccarlo...e a volte non basta neppure.
-----------------+ XBMC ENVIRONMENTS +
  + CRASHLOG_DIR    : /media/hdd
  + HOME            : /media/hdd
  + HDD_MOUNT_POINT : /dev/sda1 /media/hdd ext4 rw,relatime,data=ordered 0 0
(2)fe event: status 0, inversion off, m_tuning 1
pipes closed
pipes closed
pipes closed
[CrossEPG_Wrapper] executing /usr/crossepg/crossepg_defragmenter -r -d /media/usb/crossepg
pipes closed
0.0.0.0
169.254
192.168
AT plugin not found
ER plugin not found
poll: unhandled POLLERR/HUP/NVAL for fd 66(16)
[CrossEPG_Wrapper] <- READY
[CrossEPG_Wrapper] -> DEFRAGMENT
[CrossEPG_Wrapper] <- START
(2)fe event: status 1, inversion off, m_tuning 2
(2)fe event: status 0, inversion off, m_tuning 3
[eDVBCAService] remove channel 0x2a118d0
[eDVBLocalTimerHandler] remove channel 0x2a118d0
[eEPGCache] remove channel 0x2a118d0
(2)fe event: status 1, inversion off, m_tuning 0
stateLostLock
quello che non mi risulta chiaro, magari Angelo ci da uno sguardo, è quanto sotto:
stacca la penna, e avvia xbmc !
ok provo staccando la penna, ma non si risolve nulla. Sotto inserisco il log.
[eDVBCAService] remove channel 0x1cbc238
[eDVBLocalTimerHandler] remove channel 0x1cbc238
[eEPGCache] remove channel 0x1cbc238
close frontend 2
  + HOME            : /media/hdd
^C (sent by the kernel) <--
set wakeup time to 2015/10/28 12:55
stopService
resolve: resolve ${sysconfdir}/enigma2/lamedb
resolve: -> /etc/enigma2/lamedb
---- saving lame channel db
saved 224 channels and 3359 services!
[EPGC] store epg to realpath '/media/usb/epg.dat'
[EPGC] 0 events written to /media/usb/epg.dat
thread joined 0
set RTC to previous valid time
- (41) eServiceFactoryM2TS
- (41) eServiceFactoryMP3
- (41) eServiceFactoryFS
- (41) eServiceFactoryDVB
- (40) eServiceCenter
- (35) CI Slots
- (30) eActionMap
- (21) input device driver
- (21) Console RC Driver
- (20) DVB-CI UI
- (20) Hdmi CEC driver
- (20) UHF Modulator
- (20) RC Input layer
- (20) misc options
- (20) AVSwitch Driver
- (15) eWindowStyleManager
- (10) gRC
waiting for gRC thread shutdown
unknown client
[!] Close signal : 2
gRC thread has finished
- (9) GFBDC
- (9) gLCDDC
- (9) Font Render Class
- (8) graphics acceleration manager
- (5) Tuxtxt
- (1) Background File Eraser
reached rl -1
unknown client
[!] Abort signal : 6
Ciao ragazzi,
Scusate avete novita' per risolvere questo fastidiosetto problema di Kodi?
Chiedo pure ad @angelofsky1980 se ha idea di questo problema e come possiamo risolverlo con @insanity le stiamo provando quasi tutte.
Grazie a tutti come sempre.
Diamo per scontato che hai provato pure un altro cavo HDMI
Facciamo ultima prova, poi, ti conviene riflashare
Non basta staccare la penna, ma cambia pure il path dello scarico EPG e puntalo a HDD
Elimina lo scarico programmato EPG
Scaricati gli EPG
Riavvia il box completo
RI-/Prova ...
Ps: che TV hai ?
Scaricati gli EPG
RI-/Prova ...
Ps: che TV hai ?
Quindi cambio il path dove vanno gli epg per ora, ed elimino il DOWNLOAD automatico dell'epg, riscarico gli epg sull'hdd e riavvio il box e lancio kodi,
HO UN LG 50" FULL HD
