BH official French Translation
Here is the latest French Translation.
What has been done from the one already included in BH 2.0.2 :
- Improved translation, and some typo correction
- Removed Black Pole strings to please Tamaki ;)
- Add all srtings from Army skin : Now the default skin is FULLY translated, inluding screen titles
- Add strings from plugins present by default on BH 2.0.2 image
Tested with default Army skin, and several skins from Matrix10
This file is as complete as possible
Enjoy and please report.
Great.
Given to coder.
Hello Tamaki,
100 % of translation is done; you can give to coder.
I post new files every time something is new in Image, for example the new messages when shutting down which appeared with last BH 202B; or the new AutoShutDown in BH 202A.
Now, it is the "official" file which is very late -> so FORZA ITALIA !!! :D
Hello Tamaki,
OK, given to coder :)
@Tamaki
Here is the latest French translation including all Matrix10 skins translation. You can give to coders.
Very Important: I join also a new GUISkin.py with a modification on line 94 ( self["Title"].text = value and _(value) ) which is mandatory to have the Matrix10 skins translatable. This file goes at /usr/lib/enigma2/python/Components
@Tamaki
What about GUISkin?
Can you explain better?
What about GUISkin?
Matrix10 when coding his skin.xml files uses a widget called "Title" for printing the name of each screen in his skins. This widget extracts (if exist) the true title of the function given in menu.xml (in /usr/share/enigma2) and therefore the title of the screen is displayed and translated.
The problem starts if the function is not present in the file menu.xml. Then the title of the screen displayed is the title that Matrix10 gave to its section as a static text, non translatable, even if the string is present into the translation file.
You can easyly test it : With any Matrix10 skin, if you press for example green button, the title remains in English what ever language you did select.
See there, I did discuss about that with Matrix10 : http://www.vuplus-community.net/boa...c-blue-mx-red-diamond.12594/page-2#post-94532
Now, to make it working properly, I found that the widget "Title" called by Matrix10 is defined into the file "GUISkin.py" located at /usr/lib/enigma2/python/Components.
The mistake is that on Line 94, it is originaly written :
self["Title"].text = value ; which means that the title will be returned as it is, in other words, not translated
The modification I made is I add "and _value" :
self["Title"].text = value and _value ; which means that if the string is present into the translation file, the title will be displayed translated.
This modification does not change any thing for the other skins. I did test longly with different skins.
You can test yourself : Put the enima2.mo file into French language, replace GUISkin.py with the one I did post, Select French language,....and press green button, or any of the numerous Black Hole related menus. You will see that every thing is translated.
@ Tamaki,
Here is latest French translation updated with new strings from BH 2.0.4, and also some text lenght adapted to fit the new default skin.
You can give to coder.
Please ask the coder to give a look to the patch I gave on the post above : it is mandatory to have all the skins from Matrix10 (except the last one) translated.
@ Tamaki,
Give to coder.
@ Tamaki,
Here is latest French with new strings from BH 2.0.5. You can give to coder.
I notice that the patch given in post #52 regarding GUISKIN.py has still not been submitted to openvuplus...... Shame because it is a great improvment for every enigma2 boxes....:furious:
@ Tamaki,
Given to coder.
Sorry, i'm late :)
