Black Hole 3.0.1 Vu+ Solo2 OE 3
Hello
it is very beautiful image, but I have a small problem with Mytube can not install.
Same problem, but for me a big problem as that's my grandchildren favorite plugin. Hope it will be solved soon and appreciate if someone will inform us if there is another program/plugin that has YouTube functioning well.
How to update from 2.1.7?
Fresh installation?
The Balck hole online image update came out with nothing to update!
Yes ... Fresh installation ... But you can save first your personal settings ... Use dreamset or dreamboxedit to save your channel list, and to port to the new image.
THIS IS NOT AN UPDATE .... THIS IS A NEW IMAGE RELEASE.
beste regards
I have problem with this image, testing now, the audio has noise on some channels on DVB-T, using Sundtek USB DVB-T2, tested VTI 9 and Blackhole 3, latest driver from Sundtek is installed, it was ok on earlier images, no noise on my Sony TV DVB-T2 tuner, on Satellite channels no problem at all, i think the way they transmit is problem maybe, this image maybe to advaced, any advice??
Thanks Blackhole team..
I've just installed it and it's working really fine, I installed also my favorite pluguins, but one of them could not be installes.
it's Transmission pluguin, I tryed 2 versions: 2.82 and 2.71 but no success. I get this error message in pictures.
So If someone can help it will be great.. and thanks again.View attachment 24370 View attachment 24371
Hi guys
same problems... any idea to fix it? nedd to recompile the package?
Hello,
what are the picons used by the skin we see in the screenshots?
Are they part of the installation package?
Thanks
I updated my receiver today and it crashed after the update...
After update image or picons??
I do not know why this happened to you
because the file input_info.png from your log exists in the default skin folder orginal BH image.
Best to do is to flash image again.
Hi guys
I did a tar of transmission file from 2.1.7 and restored to 3.0.1
Some libs were missing but need to simply make a symlink with the libs that the executable is looking for.
Last problem after link all required libs is :
root@vusolo2:/hdd/ipk# transmission-daemon
transmission-daemon: /lib/libcrypto.so.0.9.8: version `OPENSSL_0.9.8' not found (required by transmission-daemon)
Any idea how to fix it?
just installed great image thanks very much.just 1 question where can i find if my clines are working and are there and ***** working
Try this one, and let us know if it works.
Thanks.. Working great, but I thinks that a password is needed to get access to transmission web interface.. this password was "dreambox" in old versions, but it seems to be changed in this vesion.. so would you please give us the new password?
