Black Hole 3.0.1 Vu+ Solo2 OE 3
Thanks.. Working great, but I thinks that a password is needed to get access to transmission web interface.. this password was "dreambox" in old versions, but it seems to be changed in this vesion.. so would you please give us the new password?
I don´t use this plugin, but:
try this:
user:root
password:root
Not tested this image yet, willing to try, but need clear answer!!, will this image be updated online all the time??, or we will have to go from one image to the other as before, i do not like the second option, that the reason not trying yet, waiting for answer???
The updates or upgrades, afaik, it will be avaiable as before. There will be fixs to fix firmware issues, and will be launched new versions, that need the full flash of firmware.
Hi all, good work but I have a big problem after fresh flash with bh3.0 I installed all plugins I want but after over night when back from work I have no more internet connection(wire) to do online update or install new settings from addons panel, IPTV player not working same ts media connection failed, but I got IPTV channel list installed to box and that's work fine same telnet/ftp function so box got connection(wire) but is refusing connection to plugins, any help or solution will be appreciate, BTW I have try to fresh flash 3x already same results. Thanks
Switch to DHCP configuration, make all online updates, set your static IP (if used).
