Black Hole 3.0.5.I Vu+ Solo2
Youtube is not working. when i try to start a video, it says internet error check your internet. the vu+solo2 i have is fully connected to the net
= "NiXoN, post: 245799, участник: 32685"] Та же проблема с YoutubeTV (Появилась несколько дней назад .. [/ QUOTE]
То же самое и на ином имидже,похоже проблема для линуксовых ресов...
I have two problems in the Black hole .... The HDD-ECC is not working 100% I need to switch on the Vu+ first to trigger also the TV. If i first switch on the TV the box is not following. In the Open pli version is works ok. And what is find strange is that when i like to change the input on the TV the TV switch back to HDMI 1. So i need to disable the cable otherwise i can select another input. Even when the box is in standby mode.
Can anyone help me with those problems?
