Black Hole 3.0.5.I Vu+ Solo2
I cant record any more with this firmware. When I try to record a program receiver create a file with the current date. Via the interface all seems ok. But when i stop recording and try to run the file which is at the bottom of the list cant start. I open the recording file via sabma at my pc and the file is 0 bytes. Anybody have the same problem?
Vusolo2 with Blackhole 3.0.5L.
How do I get installed and updated iptables (1.4.21-r0)
Need some help ..
root@vusolo2:~# opkg install iptables
Installing iptables (1.4.21-r0) on root.
Downloading http://feeds.vuplus-community.net/3.0.5/vusolo2/mips32el/iptables_1.4.21-r0_mips32el.ipk.
iptables: unsatisfied recommendation for kernel-module-nf-defrag-ipv4
iptables: unsatisfied recommendation for kernel-module-nf-conntrack
iptables: unsatisfied recommendation for kernel-module-ipt-masquerade
iptables: unsatisfied recommendation for kernel-module-x-tables
iptables: unsatisfied recommendation for kernel-module-nf-nat
iptables: unsatisfied recommendation for kernel-module-nf-conntrack-ipv4
iptables: unsatisfied recommendation for kernel-module-iptable-nat
iptables: unsatisfied recommendation for kernel-module-ip-tables
iptables: unsatisfied recommendation for kernel-module-iptable-filter
Configuring iptables.
root@vusolo2:~# iptables -F
modprobe: FATAL: Module ip_tables not found.
iptables v1.4.21: can't initialize iptables table `filter': Table does not exist(do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
opkg install kernel-module
[QUOTE = "Electrofficator, post: 248382, участник: 67208"] Youtube работает? [/ QUOTE]
Так работает ЮТУБ?
Have problem network with BH3.0.5L please fix-it
Very helpful message. Like going to the doctor and telling him:"Hey doctor, I feel bad: please cure me".
If you don't provide as many details about your equipment, your software, the situation that causes the problem and, maybe, the detailed problem itself, we are not wizards.
Have problem backup
No, it's wrong: you have a problem of COMPLETELY explaining your problem, being as more detailed is possible about the situation that causes you the issue. Here there is no wizards who can guess what happens in your box.
