Black Hole 3.0.8 Vu+ Duo2
After updating to 3.0.8.A (2019-01-07-master) I can't zap from IP-streams with service set to 5002 (ExtPlayer3). I have to go to EPG view to change program. Zapping between terrestrial channels works fine. It worked fine in the previous version 3.0.8.
Any ideas?
Any ideas?
Not possible now i'm afraid, it's a downside of the VOD skip
Is it going to be fixed in the near future?
And can I disable the VOD skip, so i can zap between the channels?
No it is the way it always was, you could only zap with left / right before because the VOD skip was broken.
Now VOD skip is fixed, you loose the left / right zap with Ext3.
How can I break the VOD skip again :glare:? There must be some way!
The only way is to use the infobargenrics.py file from a previous BH version that had the VOD skip broken.
But I will speak with other BH coders, and see if it might be possible to add an option to Select VOD skip buttons so you can choose if you want to use them or not.
That would be so good :notworthy:!
Thank you! I will try the infobargenrics.py trick in the meantime :cool:.
