Black Hole 3.0.8 Vu+ Duo2
I'm sorry but this message is useless: if you want to be sure about your (supposed) bug, do this:
1) do a fresh install
2) don't install any plugins (particularly none of the dangerous ones for autosettings) and perform a manual scan of one satellite. For instance, you tell you have 19,2E.
3) choose a channel WITHOUT subservices like, for instance, BBC WORLD HD, and press GREEN to see what happens.
Sorry: what VU+ do you have? You said Duo4K but
And, above all: have you updated to 308B? It seems you are using the first release of BH308.
Anyway, I installed MultiQuickButton plugin. Hijacked green button to something else than "sub services". Do not need subservices for anything. Still though, kind of odd if other Vu's wont crash accessing subservices.
i wonder if the file satellites.xml is really at the right place ?
i am unable to select the satellite by a list.. i changed the firmware but i am not reminding well how to use it .. i found astra 19 and hotbird 13 but i face few troubles with the motor ... [that i set as usals ]
by the way , i was forced to dismount the plate antenna , first because my settings were not very good and i discovered it was having water inside ...
by now i finish to clean it ..
i was able to test the motor with the bh3.08 and reset it with position 0
but not to make the rotor start by changing the satellite ..
thank you for help
i found it ;'] the "error" was that user must "enable" the satellite to use the search multiplexes & that is not so easy to spot...
my antenna is back in duty ;'] so i saw skynews has a big "brexit-countdown" ;']
at two weeks of the d-day...
that shows perfectly the efficiency of that europe system... the main bug is to mix big & small "countries" .. i wonder if counties are not a better choice... :help: :offtopic:
so as i was annoyed i ve used the official vu + made a month ago ...and now that i have the antenna nearly fully installed , i miss the adds of the blackhole image... :thanks: i mean like the menu where user can make move the rotor on a side or the other...:fie::yes: :inlove: .
may be someone could write an article about the images and what they add or remove to the official vu + .
that would help those having specifics wanting :welcome: :lamo:
i also ask if i can "mix" image from black hole and official : for exemple to use the image of the official firmware for the little screen...
1) I did fresh install
2) I have not
3) Green button -> crash happens with: 0.8 Thor, 4.8 Sirius also.
BBC world news 0.8W -> green button -> crash. My box is Vu Duo2
From the log It seems you have installed a malformed name plugin
please attach here your /etc/bh_plugins.pos file
Yes is the same crash.
Can you please attach here your file /etc/bh_plugins.pos ?
I found it but I can't send it.
I downloaded it to my computer but I can't choose to send it...?
DLNA/uPnP Browser:1
Kodi Launcher:2
EPG:n lataus:3
MediaScanner:4
SubsSupport settings:5
SubsSupport downloader:6
SubsSupport DVB player:7
YouTube TV Settings:8
Opera Web Browser:9
SAT>IP Client:10
StreamTVPlayer:11
Add stream URL:12
OpenWebif:13
Kuvien katselu:14
OpenMultiboot:15
LCD4linux:16
***** Info v1.3c:17
Fast Opentv Epg:18
DLNA Server:19
*******:20
TranscodingSetup:21
NetDrive Setup:22
Firmware Upgrade:23
ZappingModeSelection:24
Blindscan:25
CrossEPG Downloader:26
Manual Fan control:27
UI position setup:28
Wireless Access Point:29
AutoShutDown Setup:30
Here is the issue:
EPG:n lataus:3
What is this plugin ?
I think it is an automatic epg downloader.
I have not deliberately downloaded it myself. Came with BH...?
Hi
I have a problem but this problem is in 3.0.7 and 3.0.8 only in the other version not have this problem
The vu duo 2 is turn on in this version works fine but restart enigma2 for 2 time in 1 time not have any problem but in second time device is in screen of tv channel and after 5 or 6 sec device is crash and rstart and this problem is have for ever and this problem is not finished only for turn of and turn on device for power keyin the rear of device
How work to finished his problem ?
Thank for bh team .
Hi
Thank for bh team .
If it crashs, you should have a log.
Take a look, by using a FTP tool to:
/home/root
/media/hdd
Folders, and upload your enigma2 crash file, to see what is going on!
