Black Hole 3.0.8 Vu+ Duo2
EPG <Blue><Red>
Still not improved
Not urgent…...
Best regards
If I remember.
You probably think of the EPG panel through the Green Panel ??
This can not be changed without the new version of the image and the new version of the skins.
And for sure, we will not release new skins or images
for something like this.
Because both of them must be updated at the same time,skins and image.
Sorry.
No, you do not remember !
<Blue> <Red> should open the new "EPG sub menu" instead of opening the "EPG main settings".
You clarified this, together with the "coder", as a good idea.
And said it would be released in the next version.
Go back and look at our dialog … starting from here … Black Hole 3.0.7 Vu+ Duo2
No worries … this is not urgent … put it in … when you have the time.
Best regards
Is it possible that since updated to the latest 3.0.8A I can't explore my PC shared folders using the media player? I can't get it working. I tried everything. The thing is, I haven't done any changes on my PC. Any suggestions?
Sorry.
Best regards
This is not possible. You can open a submenu only form the menu not from a button.
Sorry.
Best regards
I've already replied,
we did not have any bugs in the skins,
to change coding for 40 skins on the server.
Something in your network because here it is working.
So it does not seem possible.
Unfortunately...
Anyways … this is minor ….
Before you did the EPG restructure … it was possible to setup and maintain the EPG settings via <Blue> <Red> … this is nolonger possible.
Best regards
Nope, just fresh install. I also made BH update (all packages get updated.. ?) still crash. Sometimes it will get crash loop. I'll reinstall once more, with all defaults. Lets see.
You are trying to open sub-services on 19e.
These changed a few months back and do not work with BH anymore.
I did not notice any image crash
on subservices Duo 4K and Black Hole image.
On which channel the problem started ?
Subservices on the Blue Movie are working correctly
The green dot displays correct subchanels.
I do not know about other subverices of channels 19 E ?.
Can't remember. Anyway, as I said default installation. Even not scanning channels yet. Well, this error/situation should be catch'ed, not assuming something is there. Anyway, keep up with the good work.
