Black Hole 3.0.8 Vu+ Duo4K
You hopefully won't have to wait too much longer.
I can confirm that I have MIS working on my Duo4K (and Ultimo4K) :)
Testing is ongoing, but there is light at the end of the tunnel ;)
Hello Ev0
Thanks testing is going on which Image OpenAtv or Obh or Bh Image can you please explain because I'm using OpenAtv 6.3 but nothing
Regard
Thanks
Hello Ev0
Regard
Thanks
Well as this is the BH forum, we have been testing with BH and OBH.
It won't work for you, as nothing has been released.
@Ev0 , excuse the question, blind search also works. ?? for others it is also important.
Disculpa la pregunta, funciona tambien la busqueda ciega.?? para otros tambien es importante.
Hello Ev0
In my bh 3.0.8 image there's no option for
Transport Stream Type. Multistream
Input Stream ID
PLS Mode
PLS Code
So why are we all using the same image but i do not have multistream options ??? 15561157537741998159927379851905.jpg 15561157537741998159927379851905.jpg
Regard
Thanks
Hi
I have a VU+ DUO 4k with the following image Black hole 3.0.8. I am unable to get any audio on the UHD channels like on 30W that have AAC audio sound.
The funny thing ius that the same image 3.0.8 but for my other VU+ SoLO2 i can hear the sound. I have managed to get these channels on a non 4K received by sending the channel bouquets from the 4K STB to my solo2 stb via dreamedit.
Any ideas what can be the cause . I see this image is from December and i found on one of my searchers as if a new driver fro DUO 4K was released end of January.
Thanks Mony
Hi
Thanks Mony
Use 3.0.9
Hi
Thanks Mony
http://www.vuplus-community.net/board/threads/black-hole-3-0-9-multistream-vu-duo4k.39010/
Use this link after say big thank you to vu+team
Hi
Please, I need help. I have problems with the sound
The sound on my box begins to hack, sounds very strange after some time on some channels.
When I zap back and forth it will be normal again.
Has anyone been having such a problem before
I have installed the latest software from vu + and black hole 3.0.9 B
