Black Hole 3.0.8 Vu+ Duo4K
vu+duo4k Multistream doesn't work with sx2 tuner. on 5° West for Rai.
We all know that MIS does not work on the receiver.
Most of your posts are the same about MIS,
you've got an answer a couple of times
If we can make you MIS we would have done it a long time ago.
This becomes forum SPAM.
Hello can you please send me the link for new update openbh or bh
Thanks
Hello everyone, I just received a new original Vu + Duo4K DVB-S2X, and I installed Black hole 3.0.8-Vu + Duo4K -2018-12-24-USB I digitized 19 ° E, 13 ° E, 5 ° W and 7 ° W without problem, I have more than 75% of SNR on all Sat. The problem is that I can not scan multi-stream channels on 5 ° W, maybe a driver problem, because it's a new model DVB-S2X? In fact, I have no option in the menu to enter: Feed ID, No PLS Mode or PLS Code! This morning, I tried the last image, Black hole 3.0.8-2018-12-24_USB, unfortunately, I could not scan any channel on 5 ° W; the others were sitting. I had the same problem with Vu + last week original image, vuplus-image-Vplus Duo4K-2018-12-24-aa3715e_USB, no channel on 5 ° W, the others were sitting OK Please, can anyone help? Thank you
As i understand the tuner inside the duo 4k is capable of multi stream just the manufacturer has to update drivers...
I really hope this will happen soon as many many users are waiting for this feature... Including me...lol...
Hello,
I have problem with switching between channels. Very often there is a long time (about 6 seconds) to switch to different program. I have VU+ DUO4k with BH 3.0.8 .B.
Have Skylink ICE card + *****. The problem is presented in the case of switching between FTA channls too.
In the syslog I can see:
Feb 25 21:19:39 vuduo4k user.warn kernel: [ 3522.549771] FE tune fe_handle=c67ad800
Feb 25 21:19:41 vuduo4k user.warn kernel: [ 3524.878768] FE tune fe_handle=c67ad800
Feb 25 21:19:43 vuduo4k user.warn kernel: [ 3527.117764] FE tune fe_handle=c67ad800
Is the problem of BH or it can to be a HW problem ?
Thanks.
Vado
The problem is solved.
It is connected to tuner parameter: pilot
Vado
Hi there is a solution to this problem image on the external flash of vu + dou4k image does not recognize the hard disk thanks
Well if you have a Viasat provided Dish and LNB the lnb is Multi.
The golden connection on the LNB is SatCR/Unicable :)
The others are regular LNB DVB-S2
