Black Hole 3.0.8 Vu+ Zero4K
Thanks for your good work.
One question please
I am having black hole image 3.0.7 already installed on my VU+zero 4k, how can I update to this version online or I have to flash it as usual?
Hello, how can I use forward or backward function with IPTV vod movies ???
Backward: 1 4 7, Forward : 3 6 9 do not work with this image.
Thanks for your great work.
Thanks and Regards
Champ
iptv working good with this update.
in service app it shows that gstplayer not installed.
how can i install gstplayer as i did not find in addons.
Reflashing means erasing the flash memory: it's like formatting an HDD and reinstalling the O.S.
What does it mean that you lost your backup? The personal backup? The FullBackup?
A backup can't be lost, it's a copy. Maybe you meant you couldn't import your personal backup?...
But this is normal. What really counts is the bouquet backup and you can do that in many ways. The rest is much better not to reimport, even when possible, but it's better to reconfigure everything.
And, as a good practice, before flashing next time perform a FULL Backup, in order to restore it in case you like or, also, to use it to install the old image in multiboot.
Thanks for your reply. Yes I couldn't restore my personal backup and I installed everything again.
Second time I will make a Full backup before reflashing.
Thanks for your help.
I won't never believe that a skin is able to affect audio... Maybe not even unofficial ones, I mean not one downloaded by the addons section.
Then try skin: Army DarkSky (for BH 3.0.7 and up)
I am using it now and sound on YouTube plugin works.
Does anyone know about the following as nobody replied.
Thanks and Regards
Champ
Thanks and Regards
Champ
It is a known problem that vu+ need to fix.
Thanks and Regards
Champ
Thanks after 3.0.8A update the Backward: 1 4 7, Forward : 3 6 9 are working.
Because you must've used a Personal Backup to restore your settings (Personal Backups are often causes of troubles.);
or, other possibility, because you might have deleted this plugin's folder manually, by FTPing in your image.
Check if your
settings
file located in /etc/enigma2, contains any lines regarding this plugin and delete them, in case.
