Black Hole 3.0.8 Vu+ Zero4K
It's a normal text file: you can edit with whatever text editor you have, even Word if you like, or the Windows notepad or the Mac TextEdit. Or LibreOffice, OpenOffice and so on... I can't know which programs you have.
And then, as I said, read it and find and delete only the lines (if there are any) where you read the name of this plugin that is causing the error you posted.
Can not change channels Iptv Via the right / left button Reverse bouquets of satellites....
Vu+ zero 4k
BH 3.0.8 A
Vu+ zero 4k
BH 3.0.8 A
Yes we know, it is a downside of fixing the VOD skip, and it is how it always was, until VOD skip was broken.
How can I change TV channels by up and down buttons instead of right and left ones? Also I want to lower and raise volume by right and left buttonns.
Thanks.
Thanks for your reply. I did as you said:
replace the keymap.xml file through a FTP software.
Extract from zip and put it in
/usr/share/enigma2
But unfortunately didn't help!!
Did you reboot the GUI? It's not possible that it doesn't work. It has always worked, even with 308. You'd be the first not to manage it to work ;)
EDIT: I've just tried and it works also under 308A
There must be something wrong on what you did: the luck is rarely involved in IT matter.
Do it again and check two things:
1. that the size of the file in the box is the same as the one you downloaded (it should be 28349 bytes).
2. that the permission are correctly set. 644 for this file.
I decided to try OpenPli.
Everything in Black Hole is complicated.
Then try OBH: it's open as well (like openpli) but I find it much more friendly and elegant.
Ans, anyway, you did not tell if you checked the two things I suggested. AMEN.
I am now using OoenPli and I see it works very well at least up till now.
Regarding your 2 suggestions, I have just seen them...
By the the way I found that option available in openpli without any complications I encounter in black hole.
And also in OBH is the same: that's why I suggested to try it. I find it much more comfortable than openpli but the core is the same and different from the one used by BH.
