Black Hole 3.0.8 Vu+ Zero4K
I only you had searched just two minutes, you would find there is no password (unless your image it's a backup and not a clean image install).
So, leave it blank.
If you installed a backup, instead, ask elsewhere because we don't give support to backups.
i have installed this version blackhole 3.8 and when i give blank in password (telnet) .its not work
Standard BH image has no password.
Which means the problem is in your PC
telnet, firewall or the like
Provided telnet is enabled within the image.
check
blue>>Blue button>>Telnet Panel
Installed this ver. 3.0.8 on new Vu+Zero 4K . IPTV VOD events - impossible to forward >> or rewind << , or pause II with this image. No good.
Version 3.0.5 allow to do that , have installed that on Vu+Solo2 , Vu+Duo and Vu+Duo2 .
Have no choice, but to try 3.0.5 on Zero 4K too. Maybe guys could fix this image?
you have to fix your skill not the image
be sure that your image is updated and
look at the customise options :)
Set enable VOD skip buttons to No in the customise menu.
