Black Hole Vu+ Duo 1.5.1 - MULTIBOOT - MULTITUNER - EPGPLUS
Thanks for the new firmware , but i prefered the 1.4.6 skin ,
mostly because it fitted the whole menu in a single screen ,
unfortunately i do use a DVB-T tuner , i have the DVB-T files , now what should i do?
Please a quick guide how to install the old nice skin?
Thnak you very much.
Install DVB-T Tuner drivers with deafult skin
and download old skin you like from Image server.
Thanks for the great job you do BH Team , realy very good image .
i wanna ask about cross epg , how to use it ? it's not working in my box after configuration, despite showing (downloading parsing ....) i got nothing .
other question : is it possible to use both BH EPG and Cross epg or there is a conlict risk ?
Thanks worked fine!
Just a note to the world .
The name of the 1.4.6 skin is Army Curve HD,
and if you want to modify the DVB-T tuner you have to do it using the default skin.
For CrossEpg you must have Storage device (USB stick/HDD)
and configured in CrossEPG Configuration.
You can download Manual and Automatic (Scheduled download)
you can download one or more EPG providers
For automatic download you have to config Scheduled download
and you have to enable providers you like to download.
You can use both BH Epg and CrossEpg
thanks Matrix10 , i did all what you said but it did'nt work , when i start the plugin i can see : downloading ... parsing ....converting data ... etc...... and when it's done i got no epg .
actually i'am happy with BH EPG , fast and efficient , just the best . but i wanted to give a try to cross epg .
For which provider You did not get Epg ?
Thank you very much for the image Black Hole 1.5.1! I have a problem with the EPG for channels JSC Sports (1-10) HotBird satellite. The EPG does not see Settings, you provider to retrieve the EPG for the JSC Sports (1-10). Please help.
Hello, a rather simple question, how much support is there in going from 1.5 to 1.5.1 and using the internal backup system in order to restore all the settings after the 1.5.1 flash is done?
Ea. is it as simple as,
run BH backup,
copy \Harddisk\backup\enigma2settingsbackup.tar.gz to local,
flash to 1.5.1,
restore backup to HDD (or does it need to be in \Configuration\backups ?),
run BH restore, restart enigma,
re-install addons such as *****.
Anything missing here or is trying to restore settings and such useless?
And what about the harddisk contents, do I need to back that up to ?
Do BH backup need internal HDD?
Is is possible to use USB-stick, i haven't never tested automatic settings restore.
Or i just map network drive, it is not so big task to do before restore :)
Yes you can use your USB Stick for backup.
You have to setup the device for backup into Software Manager options.
Hi
I installed the new image 1.5.1.A but i can't find the mean menu, when i press menu botton in the remote control i found
-Blackhole Epg Backup
-Media player
-DVD player
-Timer
-VCR scart
-Information
-Plugins
where is the system menu ?
how can i log to system menu ?
Hi
-Media player
-DVD player
-Timer
-VCR scart
-Information
-Plugins
Buttons up and down (scrollbar Mode in all Menu and panels)
Also not that CrossEPG is getting updated regularly now, you can get from crossepg.com, latest attached for your pleasure. Note that you probably have to uninstall the old version before putting the new one. I usually do this using DCCE.
Hope this helps
how do I uninstall the old CrossEPG?
hallo
there are 2ways
1- Using DCC program.
2-Pocket Management (long blue>Software Management >>advance option >>> Packet Management>>>> Mark the globe (shining Blue) @ the plugin U want 2remove,,,, fallow instruction,,etc!)
and may be also with Manage Extension!
ok thanks
