Black Hole Vu+ Duo 1.6.7 kernel 3.1.1 beta
Is det possible to install Minidlna on BH 1.6.7? My samsung tv coudn`t play any audio,video or pictures file with mediatromb on BH.
If I use mediaplayer on vu+duo everything is working fine(audio,video,webradio,pictures all formats).
If I use my home cinema(LG) it`s possible to play every audio,video and pictures format but webradio is not working(m3u and pls files).
Many people write about problem with samsung and lg tv and mediatomb like server.
Very strange!
I've found some infos about MiniDLNA but it's a very exotic version of DLNA Server ....
Very strange!
If I use Mediatomb server on my LG home cinema webradio isn`t working (pls and m3u playlist)"to much trafic" error.
I tried with audio/mpeg and audio/x-mpegurl in mediatomb webinterface without result..My mediatomb config is :
<?xml version="1.0" encoding="UTF-8"?>
<config version="2" xmlns="http://mediatomb.cc/config/2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://mediatomb.cc/config/2 http://mediatomb.cc/config/2.xsd">
<server>
<port>49153</port>
<ui enabled="yes" show-tooltips="yes">
<accounts enabled="no" session-timeout="30">
<account user="mediatomb" password="mediatomb"/>
</accounts>
</ui>
<name>MediaTomb</name>
<udn>uuid:e926bdf7-8e54-4b7e-8296-f58b792dd085</udn>
<home>//.mediatomb</home>
<webroot>/usr/share/mediatomb/web</webroot>
<storage>
<sqlite3 enabled="yes">
<database-file>mediatomb.db</database-file>
</sqlite3>
</storage>
<protocolInfo extend="yes"/><!-- For PS3 support change to "yes" -->
Uncomment the lines below to get rid of jerky avi playback on the
DSM320 or to enable subtitles support on the DSM units
<custom-http-headers>
<add header="transferMode.dlna.org: Streaming"/>
<add header="contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=017000 00000000000000000000000000"/>
</custom-http-headers>
<manufacturerURL>redsonic.com</manufacturerURL>
<modelNumber>151</modelNumber>
<!-- Uncomment the line below if you have a Telegent TG100 -->
<upnp-string-limit>101</upnp-string-limit>
<extended-runtime-options>
<mark-played-items enabled="no" suppress-cds-updates="yes">
<string mode="prepend">*</string>
<mark>
<content>video</content>
</mark>
</mark-played-items>
</extended-runtime-options>
</server>
<import hidden-files="no">
<scripting script-charset="UTF-8">
<common-script>/usr/share/mediatomb/js/common.js</common-script>
<playlist-script>/usr/share/mediatomb/js/playlists.js</playlist-script>
<virtual-layout type="builtin">
<import-script>/usr/share/mediatomb/js/import.js</import-script>
</virtual-layout>
</scripting>
<mappings>
<extension-mimetype ignore-unknown="no">
<map from="avi" to="video/x-msvideo"/>
<map from="divx" to="video/mpeg"/>
<map from="mp4" to="video/MP4V-ES"/>
<map from="mkv" to="video/x-msvideo"/>
<map from="mp3" to="audio/mpeg"/>
<map from="ogx" to="application/ogg"/>
<map from="ogv" to="video/ogg"/>
<map from="oga" to="audio/ogg"/>
<map from="ogg" to="audio/ogg"/>
<map from="ogm" to="video/ogg"/>
<map from="asf" to="video/x-ms-asf"/>
<map from="asx" to="video/x-ms-asf"/>
<map from="wma" to="audio/x-ms-wma"/>
<map from="wax" to="audio/x-ms-wax"/>
<map from="wmv" to="video/x-ms-wmv"/>
<map from="wvx" to="video/x-ms-wvx"/>
<map from="wm" to="video/x-ms-wm"/>
<map from="wmx" to="video/x-ms-wmx"/>
<map from="m3u" to="audio/x-mpegurl"/>
<map from="pls" to="audio/x-scpls"/>
<map from="flv" to="video/x-flv"/>
<map from="mka" to="audio/mp3"/>
<map from="ts" to="video/mpeg"/>
<map from="avi" to="video/x-avi"/>
<map from="xvid" to="video/x-avi"/>
<map from="mov" to="video/quicktime"/>
<map from="vob" to="video/mpeg"/>
<map from="m4v" to="video/mpeg"/>
<map from="m4u" to="video/x-mpegurl"/>
<!-- Uncomment the line below for PS3 divx support -->
<!-- <map from="avi" to="video/mpeg"/> -->
<!-- Uncomment the line below for D-Link DSM / ZyXEL DMA-1000 -->
<!-- <map from="avi" to="video/avi"/> -->
</extension-mimetype>
<mimetype-upnpclass>
<map from="audio/*" to="object.item.audioItem.musicTrack"/>
<map from="video/*" to="object.item.videoItem"/>
<map from="image/*" to="object.item.imageItem"/>
</mimetype-upnpclass>
<mimetype-contenttype>
<treat mimetype="audio/mpeg" as="mp3"/>
<treat mimetype="application/ogg" as="ogg"/>
<treat mimetype="audio/x-flac" as="flac"/>
<treat mimetype="image/jpeg" as="jpg"/>
<treat mimetype="audio/x-mpegurl" as="playlist"/>
<treat mimetype="audio/x-scpls" as="playlist"/>
<treat mimetype="audio/x-wav" as="pcm"/>
<treat mimetype="audio/L16" as="pcm"/>
<treat mimetype="video/x-msvideo" as="avi"/>
<treat mimetype="video/mp4" as="mp4"/>
<treat mimetype="audio/mp4" as="mp4"/>
<treat mimetype="application/x-iso9660" as="dvd"/>
<treat mimetype="application/x-iso9660-image" as="dvd"/>
<treat mimetype="video/x-mpegurl" as="avi"/>
</mimetype-contenttype>
</mappings>
</import>
<transcoding enabled="yes">
<mimetype-profile-mappings>
<transcode mimetype="application/ogg" using="audio-common"/>
<transcode mimetype="audio/x-flac" using="audio-common"/>
<!-- <transcode mimetype="video/x-flv" using="video-common"/> -->
<transcode mimetype="video/x-matroska" using="transcode-matroska"/>
<transcode mimetype="audio/x-shoutcast" using="audio-common"/>
<transcode mimetype="audio/x-mpegurl" using="audio-common"/>
<transcode mimetype="video/divx" using="video-common-divx"/>
<transcode mimetype="video/x-ogm" using="transcode-ogm"/>
<transcode mimetype="video/x-ogm2" using="transcode-ogm2"/>
<transcode mimetype="video/x-quicktime" using="video-common"/>
<transcode mimetype="video/quicktime" using="video-common"/>
<transcode mimetype="video/ps3" using="video-common"/>
<transcode mimetype="video/x-ms-asf" using="video-common"/>
</mimetype-profile-mappings>
<profiles>
<profile name="audio-common" enabled="yes" type="external">
<mimetype>audio/L16</mimetype>
<accept-url>yes</accept-url>
<first-resource>yes</first-resource>
<hide-original-resource>yes</hide-original-resource>
<accept-ogg-theora>no</accept-ogg-theora>
<sample-frequency>44100</sample-frequency>
<audio-channels>2</audio-channels>
<agent command="mediatomb-transcode.sh" arguments="-i %in -o %out --audio-common"/>
<buffer size="1048576" chunk-size="131072" fill-size="262144"/>
</profile>
<profile name="video-common" enabled="yes" type="external">
<mimetype>video/mpeg</mimetype>
<accept-ogg-theora>yes</accept-ogg-theora>
<sample-frequency>48000</sample-frequency>
<agent command="mediatomb-transcode.sh" arguments="-i %in -o %out --video-common"/>
<buffer size="14400000" chunk-size="512000" fill-size="120000"/>
</profile>
<profile name="video-common-divx" enabled="yes" type="external">
<avi-fourcc-list mode="process">
<fourcc>DIV3</fourcc>
</avi-fourcc-list>
</profile>
<profile name="transcode-matroska" enabled="yes" type="external">
<agent command="mediatomb-transcode.sh" arguments="-i %in -o %out --transcode-matroska"/>
</profile>
<profile name="transcode-ogm" enabled="yes" type="external">
<agent command="mediatomb-transcode.sh" arguments="-i %in -o %out --transcode-ogm"/>
</profile>
<profile name="transcode-ogm2" enabled="yes" type="external">
<agent command="mediatomb-transcode.sh" arguments="-i %in -o %out --transcode-ogm2"/>
</profile>
</profiles>
</transcoding>
</config>
hello again
I got samsung tv to play all my mp3 files and xvid,divx,avi and some mkv files with mediatom like media server.It`s showing my pictures as well.
BH 1.7.1 in flash, extract mediatomb-samsungtv.rar, usr-bin files with 755 atribut.
how to enable transcoding on mediatomb(is there mencoder and vlc installed)?
regards
