Black Hole Vu+ Duo 1.6.7 kernel 3.1.1 beta
Multiboot with Meoboo
Multiboot with Meoboot works just fine here mate...so...maybee you using wrong version.
Thanks for this wonderfull image mates.Keep up god work.
Cheers and RESPECT for yours hard work.
you mean you can reboot on other image ? like VTI 3.2 for exemple ? or you just install it ? if yes then i will try again....
After 6 reflashes I've had to call it a day and go back to 1.6.6!
Originally it looked fine but I soon realised it was really playing up....after rebooting the setup wizard would rerun sometimes, my flash was using 100% for no reason, hard disk and usb drive randomly disconnecting, plugins installing but not appearing in the plugin menu for configuration, frozen during flashing...
these were a few of the errors I was getting...back on 1.6.6 now and its perfect!
Very strange issues!
The BH 1.6.7 takes around 50% or 60% of flash.
About other issues .... you are too generic to help you
thanks for the new beta image... :D
in this new one the media player works worst than 1.6.6,tested with the same films...
wifi ok(but in the network menu the option show wlan status doesn`t work well) .
the tdt stick worked well some time but 1 hour later it stopped and didn´t open channels, with a hard reset resolved it.
the rest i think is ok, if i see anything else will advise you...
regardsss..
regardsss..
What file extension are the films you tried ?
I have watched an avi from start to finish without a single glitch.
hi black hole team
i have a serious problem with my 2TB hdd
it's inside my Vu+ Duo and everything is ok with BH 1.6.6
but BH 1.6.7 can't detect ir it
my model is : Seagate
Great work. But a I've a problem with script Backup IMG HDD. You can install it, but when you execute this script, doesn't work.
Anyone with the same problem?
Thanks in advance
My friend read first post:
WARNING: THIS IMAGE USES A NEW FILESYSTEM AND IT IS NOT COMPATIBLE WITH MULTIBOOT OR WITH OLD PERSONAL BACKUP.
I read it. I'm not talking about PERSONAL BACKUP. I refer to the script Backup IMG HDD for image backup. They are two different things.
hi..
for example with this file:
Formato : AVI
Formato/Info : Audio Video Interleave
Tamaño del archivo : 347MB
Duración : 40min.
Tasa de bits total : 1 185Kbps
Aplicación de codifición : Lavf52.20.0
Video
Formato : MPEG-4 Visual
Ajustes del formato, BVOP : No
Ajustes del formato, Qpel : No
Ajustes del formato, GMC : No warppoints
Ajustes del formato, Matrix : Default (H.263)
ID Códec : DIVX
ID Códec/Info : Project Mayo
ID Códec/Pista : DivX 4
Duración : 40min.
Tasa de bits : 1 044Kbps
Ancho : 690pixeles
Alto : 380pixeles
Relación de aspecto : 16:9
Velocidad de cuadro : 25,000fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8bits
Tipo de exploración : Progresivo
Bits/(Pixel*cuadro) : 0.159
Tamaño de pista : 306MB (88%)
Librería de codificación : Lavc52.27.28
Audio
Formato : MPEG Audio
Formato de la versión : Version 1
Formato del perfil : Layer 3
ID Códec : 55
ID Códec/Pista : MP3
Duración : 40min.
Tipo de tasa de bits : Constante
Tasa de bits : 128Kbps
Canal(es) : 2canales
Velocidad de muestreo : 44,1KHz
Tamaño de pista : 37,5MB (11%)
Alineación : Alineación entrelazado
Entrelazado, duración : 26 ms (0,65fotograma de video)
Entrelazado, duración de precarg : 26 ms
i have tested a lot of diferent file extension and all have freezes...i think it would be caused because i play them in network,maybe the problem comes for network playback, the media files are in my computer, but with previous images all of them worked ok.
I hope it helps, regardsss...
@ franron:
Anyone else having problems making a backup of this image ?
Have reflashed twice, used USB and HDD script from addons panel, both were unsucessful.
The new kernel use the new Ubifs file system that is not compatible with old tools designed for JFFS2 file system.
More here: http://www.vuplus-community.net/board/threads/blackhole-vu-solo-1-6-7.4285/#post-35282
I just saw the wifi shows 54-90 Mb / s when my wifi dlink model is 140 N and before with the image 1.6.6 always displayed 270/300 Mb / s, maybe the wifi driver is not well tuned, this image detect it with the driver rt2800, is it ok???
regardss...
