Black Hole Vu+ Duo 1.6.7 kernel 3.1.1 beta
i don't know if more people happening.. but we i watch a program from the hdd, stops the image from the hdd a lot.. and i have to press foward and works again.. and then later on happens again...
any idea??????
I just saw the wifi shows 54-90 Mb / s when my wifi dlink model is 140 N and before with the image 1.6.6 always displayed 270/300 Mb / s, maybe the wifi driver is not well tuned, this image detect it with the driver rt2800, is it ok???
regardss...
i can confirm this is the problem of network playback errors in my Vu, the new image autodetect my wifi stick(dlink 140 N) with the driver rt 2800 when with the image 1.6.6 it was rt5370 sta and with this one it works perfectly...
i hope this information will be helpfull...
regardsss...
I CAN CONFIRM there is a bug in this new black hole.... receivers with hdd have problem, sometime stops we you watch a recorded program and i have to press foward and works again and stops later again, and again...
My HDD is mount ok, when I´m watching tv, I push yellow button for timeshift and screen go Black, and not work until I push stop button. In BH 1.6.6 or olders it working OK.
Regards from Spain
P.D. Sorry for my bad english.
Regards from Spain
Reboot STB,,,,try few times the Timeshift and it should work, however I confirm that some times, I can see black Pic not freez Pic ,,,,but the TS is still working!
What is the date of latest drivers U installed!
Try it a gain with Dolby D. Dmix....off!
I reboot for two times and now works fine ;)
Regards
Thanks a lot, I have a small problem with Hdmi-cec. It will now work with my LG, but it won't change to the correct input. For example, I'm watching a DVD and then switch the TV off to standby. If I now turn the Duo on, it will automatically turn the TV on, but to HDMI-DVD input. I have to manually switch the TV to HDMI-sat. I've set the correct input number on the Duo settings (HDMI 2 in this case).
connect box to HDMI from the dvd.
exchange connector :idea:
p.s
Have you made a HDMI ports SCAN after VU configuration
in your TV HDMI setup ??
connect box to HDMI from the dvd. exchange connector :idea:
The problem is that when the TV is switched on by the DUO , it just starts to its previously used input (HDMI multiple inputs, or antenna). It won't change to the HDMI input the Duo is connected to. That's fine if I was using the Duo (watching sat) the last time the TV was switched off, but if I was watching anything else (DVD, terrestrial TV etc.) the TV has to be manually switched to the DUO's input again.
Yes I understand,
I have no problem with the Sony and Samsung
After scanning ports
uno and duo were correctly detected.
