Black Hole Vu+ Duo 1.6.7 kernel 3.1.1 beta
I've installed the last BH with Pinnacle 340e as DTT tuner and a zd12211rw wifi chipset as dongle.
The wifi AP scanning fails (on screen appears the message "scan AP failed), while the DTT tuner won't work (if I select a DTT channel, the blu circle on the upper left corner turns until I shut down the box from the rear button). If I use a A867 chipset DTT tuner, the box works without any problem.
Wifi tested also with TP-Link TL-WN321G (rt2870 chipset) and TP-LINK TL-WN422G (Atheros chipset: now supported!), without any problem. Still have issues with zd12211rw.
P.S.: when I switch on the box from standby, it turns on slowly than the older version, with a quick "blue circle"/black screen and then it shows image.
Anyone else having problems making a backup of this image ?
Have reflashed twice, used USB and HDD script from addons panel, both were unsucessful.
hi black hole team
i have a serious problem with my 2TB hdd
it's inside my Vu+ Duo and everything is ok with BH 1.6.6
but BH 1.6.7 can't detect ir it
my model is : Seagate
EleganceHD PIG for BIG Picon 130x80 BH 1.6.x
you can download from image server.
This skin is default skin in BH 1.6.7​
Have you read the specs ?
This is a beta image. The new kernel is not yet officially released by Vu+.
You are testing a preview.
Do you think you have enought for now ?
I'm well aware it's a beta. I'm sure that you are aware that when adding to or messing with an image, especially a Beta, it's easy to mess things up. So keeping regular backups is a good idea!
To answer.
Yes with one but
it's too much to ask all at once
After such a great job with the new image and the kernel.
Rgd MX
