Black Hole Vu+ Duo 1.7.5 "Multiple"
it will be great if we can receive an email as a VU+ member's group when a new image is release , just to be the first to enjoy it ! hope the team will do it next time. like that, we will feel like VIP :cool:...
thanks in advance!
Yes,had the same problem.Also green screens on me on certain channels,BBC 1,Watch HD etc.Gone back to 1.7.4
Again the problem is in the SAT list you're probably downloaded from the server and not in the image.
You have download Catseye settings ?
I have remove this old settings from our server.
I will look for new one.
Can not install Ipk packages manually.Do you have same problem.thanks in advance
IPK install working without any problems..
Or you used a bad IPK file
or a plugin/addon that does not work in image.
Copy ipk file to /tmp
install with
green>>yellow>>Manual Install Ipk packges
maybe you have the best epg system but not the best usb support for usb pen that is not working 100% you make the best image i must confirm but with issues
thanks for the best images on vu+ :-)
My channel list works with 1.7.4 ,think I used the Don@e2 settings for 28e+19+16+13e tbh
thanks for the best images on vu+ :)
use USB that works well with your box
Unfortunately not all work well
It is so with all boxes and images.
But not with BH 1.7.5
I tested yesterday with list from Likra upload with DreamboxEdit and not from the server.
I think download from the server settings list is not always good
because it does not delete the existing list and does not correct the errors in the list.
My advice use DreamboxEdit
take look errors in list only a small part
Info 2012-06-03 14:10:42 dreamboxEDIT 5.0.2.0 started
Info 2012-06-03 14:11:05 Directory E:\Dreambox\DM800\DreamBoxEdit\Catseye selected
Warning 2012-06-03 14:11:10 Duplicate TV favourite (userbouquet.sky_uk_epg_.tv) not loaded
Warning 2012-06-03 14:11:10 -- data: #SERVICE 1:0:1:d42b:a2c:2:11a0000:0:0:0: (service: JML Cookshop, bouquet: Sky UK HD EPG )
Warning 2012-06-03 14:11:10 Duplicate TV favourite (userbouquet.sky_uk_fta_freesat.tv) not loaded
Warning 2012-06-03 14:11:10 -- data: #SERVICE 1:0:1:d42b:a2c:2:11a0000:0:0:0: (service: JML Cookshop, bouquet: Sky UK FTA/Freesat SD/HD)
Warning 2012-06-03 14:11:11 Duplicate TV favourite (userbouquet.sky_shopping_.tv) not loaded
Warning 2012-06-03 14:11:11 -- data: #SERVICE 1:0:1:d42b:a2c:2:11a0000:0:0:0: (service: Warning 2012-06-03 14:11:12 Duplicate TV favourite (userbouquet.viasat_sweden.tv) not loaded
Warning 2012-06-03 14:11:12 -- data: #SERVICE 1:0:1:c58:5:56:300000:0:0:0: (service: Comedy Central, bouquet: Viasat Sweden)
Warning 2012-06-03 14:11:12 Duplicate TV favourite (userbouquet.viasat_denmark.tv) not loaded
Warning 2012-06-03 14:11:12 -- data: #SERVICE 1:0:1:d7a:15:56:300000:0:0:0: (service: Nickelodeon, bouquet: Viasat Denmark)
Warning 2012-06-03 14:11:15 Duplicate TV favourite (userbouquet.atlantic_bird_1__12_5_west_.tv) not loaded
Warning 2012-06-03 14:11:17 - errors in services file: 0
Warning 2012-06-03 14:11:17 - errors in bouquets file: 0
Warning 2012-06-03 14:11:17 - errors in userbouquet.xxxxx.tv file(s) (TV): 26
Warning 2012-06-03 14:11:17 - errors in userbouquet.xxxxx.radio file(s) (Radio): 0
Warning 2012-06-03 14:11:17 See earlier logged messages for more details
Warning 2012-06-03 14:11:17 Explanation of errors found within TV and/or Radio User Bouquet:
Warning 2012-06-03 14:11:17 .. All files are loaded but unsupported references were found in the TV and/or Radio User Bouquet list!
I used Dreamboxedit,even flashed the image/channel list twice just to make sure I wasn't doing something wrong,end result the same,not to worry,1.7.4 is still great :)
No problem here,
You can also make scan if you have bad SAT settings.
hello all
missing something important!
why has nobody thought a menu lock adjustment by a password? this is a very interesting option and absolutely necessary to keep its settings ..... question: when? ...
thanks
