Black Hole Vu+ Duo 1.7.5 "Multiple"
You have 2 options,,,!
1- Pratnal control.
2- Settings backup.
I use both,,and they are working fine!
no, locked TV channels for adults it's other things we speak password to prevent changes to settings.
the solution is a backup safety, but not the solution.
thank you
Bonjour, comment enregistrer sur disque dur les radios diffusées par satellite, exemple France musique fip etc: merci pour la réponse
Système menu >> Personnaliser (mode expert ) >> Mode radio Alternative >> OUI>> OK
Menu System >> Customize (Setup Mode Expert>> Alternative radio mode YES >> OK
I have installed BH 1.7.5 on my VU+DUO. |Using Vu+CC I have "installed" with IPK Installer the plug ******* 5.8_mispel.
I gives me the following errors:
*Package enigma2-plugin-extensions-******* wants to install file /usr/script
But that file is already provided by package *vuplus-blackhole
* Cannot find package enigma2-plugin-extensions-*******.
root@bm750:/tmp#
What I have done wrong? Any assistance please...
root@bm750:/tmp#
This thread deals with the BH image not with the external plugins.
If there is any plugin problem, you have to contact his author.
First , thanks to the great team.
I enjoyed BH 1.75 for few days.I installed , because of i am curious, some ( 5 ) other recent unofficial images on multiboot ( mounted usb exclusively dedicated) .All other image work well!!! but when i restart and boot from flash ( BH 1.75) it stops on botting gui.My question is : can unofficial image installed on multibbot corrupt the flash?
Thanks for your reply
It's possible when you make online updates into multibooted image who something on the flash happen......
So sorry for a noob question but I upgraded Black hole image from an earlier version to 1.7.3 and i lost my lets say the thing you cant talk about here.
I had all my other stuff back up bouquets timers on the DB control centre so that was OK.
i wont to upgrade to 1.7.5 is there a way I can do it without bugging him at his place?
I know how to FTP files if that helps and how to upgrade the black hole image but cant seem to keep the important stuff.
sorry again for the noob question I am still learning,
thanks for reading.
thanks for reading.
If you have an HDD or an USB stick connected to your Duo, you can make a backup via "BH Personal Backup" plugin and after installing the new image you can restore it.
Menu > BH Personal Backup
yep I thought i did that, I have 500 gig internal HD when i went to upload it back there was noting there!
so i had it backed up on the DB control centre but not the thing we can talk about'
maybe I be some thing wrong the first time iam gonna try backing it up now i let ya know thanks for the quick reply Mito
Thank you Please explain to make things easier on everyone Version of this topic is well known that four-in-one copy And should be placed in the internal flash And then became possible installation Is the intention here meoboot installation, for example, or is it only works on the internal flash and Multi Universes Does it work through usb or only from the internal USB stick And what the feasibility of multi partition of the memory stick I mean to Division what can be learned What is the benefit and Multi UPnP servers I ask the experts on this topic provide an answer to the questions that we will not be able to become a professional and we suffer from the problem of understanding the basics . thank you for your patience.
Excellent image, but when the driver update to improve vidimosti.Ato I live in Russia and we do not have very good quality
...not again....... DVB-T Redi usb stick broken.... the bad thing is that i didnt do a FULL backup before :(
ps. it is recognised as MDTV Receiver (DVB-S2)
