Black Hole Vu+ Duo 1.7.8
Yes, I confirm that!
Just tested!
Am sure the Admins will look into it, and find a solution.
I have a few issues,
Green screen when trying to stream movies with 1channel usb version on bh server
Advanced Movie selection do not work. None of the versions on BH server.
How to use HbbTV?
Just tested!
I have a few issues:
Advanced movie selection do not work, none of the versions on BH download site.
Green screen when trying to stream with 1channel usb version downloaded from on BH download site.
Vu+ iPhone app works very poorly since around BH 1.7.x, a lot of freezeing.
How to use HbbTV?
How to use HbbTV?
-AMS v2.7r0 plug-in works fine, I use it all the time.
-1channel worked fine, when I tested it last time,,,will try again later!
-Vu+iPhone app,,I do not use it,,,however I think it still under Beta Testing!
-For HbbTV , look into channels @Astra 19.2,,like ZDF , few german channels have this feature , press RED or long Blue to activate!
For plug-in to be compatible with a plug-in , you have to talk to the authers to make it work with the image!
RgdZ
RgdZ
so there is none on Hotbird? I can only get Astra 1M 19.2 and it got alot of German/french channels but no ZDF :(
on the other hand- this image looks very stable to my Vu+Duo.
running on avalaon universe with 512 MB swap on USB
thanks BH team for the nice work
Any tutorial + explanation for buttons in Hbbtv or Web-browser will be Useful Please; We need it... Thanks In advance
Thanks verymuch, this update came ontime, i got problem with 1.7.6, Clock was showing wrong Time,
Timezone is correct, but time still wrong, hope this update correct time clock or add feature to set and correct clock time manual.
Thanks,
Just tested!
Bad news, i heard the problem is by youtube, they changed a parser or sometthin like that. :(
So it has nothing to do With our Blackhole i gues,
Regardz,,
Finally I found an HbbTV on Hotbird
it is on Tve international and it works fine.
see below snap shots of my TV
Hello
Bravo for your work!
Excellent as usual!
Salut , Bravo pour votre travail et excellent comme d'habitude !
Al
For some reason when I load this image the box hangs on reading USB, I have to remove the USB formatted in EXT2 by a previous BH format wizard to start the box. I can re-insert the USB just after starting appears on the front.
I tried re-formatting with this image and it's just the same - there are no files on the USB. I formatted again in FAT32 and it boots OK
