Black Hole Vu+ Duo 1.7.8
You have compleatley lost me. Please read my thread carefully. I did install the full BH1.7.8 with HbbTv. All this runs ok, the problem is the PLUGINS Folder in BH Menu disapears (Gone). Why?
I reinstall BH 1.7.5 and all is ok.
Why does the PLUGINS folder dissapear in BH 1.7.8?
del
If you restore a backup when you install the new image, you can try to reinstall the image without restore it.
will give it a go, any other suggestions
Thanks
Your Plugins disappear because you have put in
System Menu >>Customize to Setup Mode ...Simple
If you put in Customize Panel setup mode to Expert and SAVE
Restart image you will have all options and Plugins Menu
Thanks for the reply, Set back up again last night and all seems ok at this time. I will keep your comments in mind.
For interest I never touched anything in Menu other than check dish settings. Fingers crossed it stays ok this time.
I found the HbbTv channels in 13E- impressive.
del
del
Hi,
I"I was running BH 1.7.5. on my Vu+ Duo. I upgraded to BH 1.7.8 without HbbTv. The install completed 100% ok. All my settings were installed"
This what was written in your post!
And I do not know why U lost your plugin folder!
Hi all
I just update my image from 1.7.7 to 1.7.8 last one, all working fine except channels display on LCD display of the box. All time it show Main menu or something else, but not channel name.
Do I have to reload the image or it is something else I have to do?:(
Installed this image, now getting green screen crashes.
have upgraded the bootloader and have activated a swapfile on my hard drive.
the VU+ DUO receiver is genuine
all was ok before i done the above.
where is the crash log kept on my receiver.
Crashlogs are stored into /hdd folder on your box. Upload here the latest.
I set the disk system sleep after 1 minute, generally it works, but in one case does not put to sleep disk
blue, yellow button (system info) exit from the menu, disk is no longer put to sleep
so it has to be if it's a bug?
Tried this but no luck still getting crashes
Hi to all. I have problem with yellow button. When I press it, it shows Select audio track but no Time Shift. Where is Time Shift button now??
Thanks a lot for this info.
However, can someone explain why the 1channel stream plugin is freezing every few seconds, using1.7.8
Am not constant user of this plug-in, but I think the freeze coming from the internet speed/connections!
Thanks for the upgrade, I have 2 issues
1. the stb halts randomly when watching tv
2. I cannot install the redi pc 100 drivers!
any help is welcome !
snet.
