Black Hole Vu+ Duo 2.0.5 galaxy
Hi,
I've just installed this image, last image installed was a while back, can't remember, as I've upgraded OS on my PC, so got rid of the files on the desktop (could have been 2.0.3 ??). Anyway the hard (which has many of my films, recorded from previous versions BH images), did not mount. I am going to try to mount manually. Will get back to you...
In fact when it reboots, in Device Manager, it says:
'HARD DISK ATA SAMSUNG HD103SJ 1000.202 GB sda1 Not mapped'
This is exactly the same as when before I mount it in Device Manager
In /etc/fstab, it gives this after the mount in Device Manager:
UUID=<long alphanumeric number> /media/hdd auto defaults 0 0
big thx to all involved.....
Before i try..yet again is this possible to update online..??
will the formation delete all my stuff i have on hdd right now..??
you can't update image on-line but you can use personal backup and restore it after update.
If you'll try to format your drive this operation will delete everything on your drive, but you don't need to format your drive again if you've been using your drive with previous versions of bh
