Black Hole Vu+ Duo 2.0.5 galaxy
no good to me everytime i try to setup the epg while prsing the event it crash's and then loops in green screen no pluging's installed only thing i had was catseye list and using ghost universe
if you have trouble after flashing please open new thread and describe your problem together with full box configuration (mounted devices, swap, extended flash, etc.)
I've tried 4 different images from 1.7.8 - 2.0.5, each time when I reboot my box it gets stuck on startin ? I've reloaded the backup I done before I tried updating and everything works ok. Just can't upgrade for some reason. ANNOYING !!
What kind of devices do you have connected to your box when you restart it?
a new error dev blackhole left it on the source and meoinit meobm in the image blackhole 2.0.5 in / usr / src / debug
I have to reboot duo 2-3 times a day since I started using 2.0.2. Now My duo is on 2.0.5b.Freezing like ice in winter recording when recording one channel and trying to watch another(use to be able record 6 channels from two transponders).Is my vu duo slowly dying here or we have software issues (images for duo getting heavier )
Great job guys but how can I turn off subtitles, which are on by default. I cannot find an option anywhere. Thanks in advance.
I wish to have your problems: button next to home on the left.
Or blue blue -you should find advanced subtitle settings there.
can you post your crash log again as I can't read it using notepad
