Black Hole Vu+ Duo 2.0.9
"Add option: "Preferred tuner" Available in menu->setup->system->customise (Expert mode). Configure which tuner will be preferred, when more than one tuner is available. If set to 'auto' the system will give priority to the tuner having the lowest number of channels/satellites."
Is this different with "priority" option in tuner configuration ( advanced mode )?
Is different this one is Tuner priority
In advanced can only be used for advanced configuration for a single LNBs/positions but not for rotor / USALS, DiSEqC A / B / C / D and A / B in simple config mode.
I think, but I have not tested im not using advanced mode.
excellent work
but usually 1 thing to add for img blackhole vu+duo
it is : blindscan (it is a very important plugin )
in dreambox there is this plugin but in blackhole vu+duo (no)
so please can you add it in the future img ????
excellent work
It can only add VU +
but as far as I know HW from Duo tuners not support blindscan.
hi
a simple box can do it !!!!!!!!!!!!!!!!!!!!! LIKE STARAST OR SAMSAT ....
vu+duo the good one don't able to do blind scan !!!!!!!!!!!!!!!!!
not normal :eek:
hi
not normal :eek:
When the Duo was launched (over 3 years ago now), E2 was unable to support blindscan, so the hardware didn't need to support it either.
