Black Hole Vu+ Duo 2.0.9
Am I the only one to have problems in changing crypted channels on DTT?
With older BH images I had non problem. I use A867 tuner.
Strange behaviour when updating. I did everything as usual but this time the display remained stuck on "Programming....". After 15 minutes I decided to turn off the decoder and turn it on again and the new image was there :D.
Great image BTW!
Install BlackHole 2.0.9
Tuner saw, but why not find channels. we are broadcasting on 578 Mhz DVB-T2 On the computer all the channels lock
LOL!
I suppose you have an AstonMeta DVB-T2 Realtek rtl2832 chipset based, I'm right?
If I'm right, your previous question was wrong because the most correct question should be: "The device <brand> <model> is supported?". With the generic chipset question, the answer will be YES ....
About your "problem" there is the possibility that the DVB-T2 support for your USB DVB dongle is not yet avaiable.
yes, you're right. Here is the link, only in Russian.
http://mysku.ru/blog/others/20164.html
DVB-T2 means until supports them. I'll wait.
thank you
Edit by moderator. No live links, Please.
