Black Hole Vu + Duo v 1.4.5 Multiboot
thanks best image ... number one
Blank screen after installation from USB. I copy the image on the different USB stick. I repeat several times with the same outcome. No boot no bootlogo, no nothing. I put back BH 1.4.4.
I think you should try to download img again, maybe your file has got some problems if you cannot flash it, or it doesn't boot after flash.
Excellent job guys. Very nice Army skin now, much better than earlier. Fast zap etc.
Thanks very much any included
regards
acer2
The Flashing process is OK.
It doesn't boot after flash.
I downloaded again, but the same. Blank screen after reboot.
When I tried to put VIX v1.3 several month ago I experimented the same.
Pli OK, VTi OK DreamElite OK BlackHole 1.4.4 OK.
So Blank screen with Vix v1.3 and now with BlackHole 1.4.5
That is really strange, there is no reason it shouldn't boot.
Try to boot unpluging all your extra hardware.
