Black Hole Vu + Duo v 1.4.5 Multiboot
That is really strange, there is no reason it shouldn't boot.
Try to boot unpluging all your extra hardware.
So I put the image without my NTFS Hard , and boot ok. But after I connected the NTFS Hard the box not booting.
So the image try to access the hard drive and this stop the booting process, I think.
Maybe because it's write protected until I mounted with ntfs-3g.
I tried the new VTi 2.4 with the new enigma drivers from Vu+ and works.
So please check it.
Thank you.
hi everything works great exept when i whatch a movie whith media player and want to pause the movie it stops ok but when press play again it starts from the begining off the movie and not wher i stoped it any sugestions ? i hawe the movies on hdd on box br:sat
Are there any special stting then i have 2 do,
i would like use EPG, from TVV, canaldigitaal, and SKY UK, SKY IT etc (there are 2 seperate thing from SKY UK, what is the difference ??? )
They just come from a different source, I use satmate for UK and IT others prefer rytec. The choice is which you prefer.
When you pause a file, press again pause and start when you have paused them.
