Black Hole Vu + Duo v 1.4.5 Multiboot
Hi All,
I tried to install -cooltvguide_Coolman_V2.2.2 but it doesn't show anywhere. I downloaded the ipk, manuall installed it but can't find it anywhere. Where does it go or is there a special version for BH images?
Cheers
Try a long press of epg botton, then select cooltv guide.
Make a swap on usb or hdd and everything will be ok :)
With the swap, it crashed again last night .. (los the crashlog 4 this one :(
Still very anyoning trouble with EPG.
when i manual dl 'd epg for let say SKY UK, after that i lose the EPF from BE and NL ????
i really don 't get it ...
Will try to look into it this evening ...
could it be a problem with the channellist or so ???
I had a crash last night when manually downloading the EPG. I was downloading Satmate_UK. EPG.dat saved on media\usb, I have a 256MB swap file on media\usb. After the crash and enigma reboot, I downloaded satmake_UK and _IT no problem.
I am attaching the log, can the BH team take a look at it and let me know what the problem is?
Thanks for the help
Thanks for the help
Try to store epg in global settings in /media/hdd.
Epg panel in BH is born to work very fine in hdd.
Hey Tamaki, I changed the EPG path to media/hdd, selected Csat, green screen.
After reboot, selected media/usb, downloaded Csat, fine, downloaded Satmate_IT, fine, downloaded Satmate_UK, green screen again.
Not great
Logs attached.
What should I do?
Not great :sad:.
Logs attached.
What should I do?
I think you selected to many epg providers.
Try if you have green screen always with your third provider.
Thanks Tamaki
Yes, it seems to be the case, although the first time I tried today with Csat it green screened straight away.
Surely I am not the only one with this problem. Is there any solution? I have a 256MB swap file.
Thanks Tamaki
Also have/had this problem, with the EPG.
Now using CrossEPG (see post above from Zupy), and it seems to work ok then for now
Do not download epg from sky de because there is already in the stream and after a few seconds on some sky de channels you will get it completely.
Hi,
When you watch a recorded video from hdd and as you watch you have a recording timer set to take place in the time you watch from the hdd the recording set is never started.
When you have a channel recording and a second channel as a timer set to record and you are watching the first recorded video that is still recorded and the second timer set is taking place and started will work :)
Regards
Hi,
Regards
1st statements may not be correct,,,,timer will start automatically and recording will start while watching a recorded file in the HDD!
2nd statements is tru,,,not only that,,, Also U can recored more than one channel, if they are the same frequency or 2 tuners!
The PIP is only a image refresh every 5 seconds I think so it will look like it's hanging. This is a first step until vuplus gets the full stream implemented (if at all possible)
