Black Hole Vu + Duo v 1.4.5 Multiboot
BH 1.4.5 is great but I dont like changes in displaying "color" buttons in menu. It is too small! Shape and size in all previous versions BH was much better. My wife is ill with eyes, now she isnt able to recognize this buttons (on 46" TV) :-(
If you don't like it, you can download and install some other skin by BH Addnos Manager.
i pressed pause on an hd channel when back after 5min and pressed play i had a subtitles lag. Subtitles where 2-3 sec faster than audio+video.
Another crashlog :) Enjoy
No,,,enjoyments,,,,
BH IMAGES , starting from BH .12 (a year ago, for 800 HD) up to BH 1.4.5 (for Vu+).
Never have crashes ,,,,Only when we users put incompatible skins or plugins,,,,,!
EPG still does not work as it should here :(
when it updates, i get a crashlog
"BlackHoleapi: extepg,Rytec-BE-NL,http://www.xmltvepg.be/benl/epg.dat.gz
main thread is non-idle! display spinner!
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 10030676 bytes for cache used
[EPGC] 176438 events read from /media/usb/epg.dat
[EPGC] store epg to realpath '/media/usb/epg.dat'
[EPGC] 323703 events written to /media/usb/epg.dat
[EPGC] 13922026 bytes for cache used
PC: 00480734
00000000 10008b01 00000001 2c977860
00000005 00000001 00000001 00000001
00000001 00000000 00000001 00000001
00000001 0000003a 2c977860 2b512ca8
005cd5d4 01c61398 008cc104 00000000
0004f077 7f991fec 7f991ff0 7f991ff8
00000000 2b42f6a8 00000001 00000000
2b51b960 7f991f98 2ea8924c 0048072c
As a final action, i will try to dump a bit of code.
I just hope that this won't crash.
00480734: 01 00 87 90 02 00 e5 24 a4 1a 11 0c 21 38 20 02 9c 1b 11 0c 21 20 00 02 18 00 a6 8f 21 80 40 00 (end)
</enigma2crashlog>
<pythonMD5sum>
<!-- Cannot allocate memory -->
</pythonMD5sum>
</crashlogs>
</opendreambox>"
allready changed path to media/hdd and /media/usb
crashes on both
@VenimK: never had any issue with EPG on TVV/Canal Digital NL/Sky UK. But I don't use any USB or internal HDD storage, instead of that I use my Samba Fileserver.
I'm using BH since version 1.3.6 never had any big problems, so BH team you rock ;-)
It's only a pitty that I can't stream my Sat TV channels to my PS3 or other DLNA media. I did try to test it with MediaTomb in BH 1.4.4 but my PS3 don't see it. (PS3Media server on same network segment did work perfect!)
Hi All,
I tried to install -cooltvguide_Coolman_V2.2.2 but it doesn't show anywhere. I downloaded the ipk, manuall installed it but can't find it anywhere. Where does it go or is there a special version for BH images?
Cheers
