Matrix10
I have 2-3 green screen per day. Is not too much? I am attaching the last.
Do you have a lot of EPG downloads ?
Thanks for your answers. To Matrix: no, I have not, - to angelofsky: what can I do? Any solution?
Hi jbond,,,!
Can U post/grap pic of your Reception Setting ,,,,,,The Admn Angelo is right most of the error @crash log is about rotor locking!
grab -p
Thanks, I try to do itTo grab the screen you can use the following command issued into a telnet session:
Code:grab -p
The result is a screenshot.png into /tmp folder of your box![]()
Hi a911.Hi jbond,,,!
Hi a911.
Can you more detailed with "Reception setting" ? I can grab the screen, but I don't know what screen.
I am attaching the two screenshot and the latest crash file made it when I grab the "tuner settings" screen. Thanks for yours patience to my problem.![]()
