Black Hole Vu+ Duo v. 1.4.6 Multiboot
Thanks.
Good job. Nice image...
The font of the new skin has problems with the Spanish language.
For example, the channel is called: C+ FÚTBOL HD and the program: MÁS DEPORTE (HD)
Kisses from Spain.
Katia.
It is not difficult to fix this problem
but with a different font
I think my friend Army will soon put a new skin.xml
coding file with a different font.
Of course you can use any other skin that gives you a good fonts.
This applies equally well to some other languages.
If some of colleagues tried to put new drivers on BH 1.4.5 and if it work normal, please write here that.
You can update image with new drivers
But will all work as the new image is hard to say
because we have not update only drivers .
And the Greeks has problem.Not appears correct. Thanks.
To solve this, just edit skin.xml in /usr/share/enigma2 to use Army_Regular_L.ttf font instead of the default HandelGotD.ttf font.
Your new line should become:
<font filename="Army_Regular_L.ttf" name="Regular" scale="100" />
Save, restart enigma2 and choose Greek language. Everything should be OK now.
Maybe the Army_Regular_L font would solve the problem for our friend from Spain, too. I have not checked completely the font but I see that it implements a really big set of characters...
If you want to use this font it seems to me too big
but you can fix this
<font filename="Army_Regular_L.ttf" name="Regular" scale="95" />
problems with epg on bulsatcom wont show epg on channels and also makes channels shift heavy, no problems on other channels, have installed xstreamer usb wifi 150 mbit with realtekchipset RTL8188SU it shows in the network menu and you can set it up but it wont get ip adress, because it is reconnecting all time as i can se on my router that it is on and off etc...... and maybe because it cant run N mode ?
For realtek issue can you post some details about your device? Should be very useful the USB IDs of your device :)
OpenEmbedded Linux bm750
Vuplus 2.0.5 + BlackHole 1.4.6 bm750
bm750 login: root
root@bm750:~# cat /proc/bus/usb/devices
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0000 ProdID=0000 Rev= 2.06
S: Manufacturer=Linux 2.6.18-7.3 ohci_hcd
S: Product=BRCM OHCI
S: SerialNumber=ohci-brcm
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
S: Manufacturer=Linux 2.6.18-7.3 ehci_hcd
S: Product=BRCM EHCI
S: SerialNumber=ehci-brcm
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=256ms
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0bda ProdID=8172 Rev= 2.00
S: Manufacturer=Manufacturer Realtek
S: Product=RTL8191S WLAN Adapter
S: SerialNumber=00e04c000001
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=ff Prot=ff Driver=r871x_usb_drv
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0d(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
here u go
Hi Guys
I have installed the latest BH 1.4.6 in my flash and also added the NEW ADDONS SERVER from Nab*** but its giving me ERROR.
The Image BH 1.4.5 was working fine without the above mention NEW ADDONS SERVER
Am I doing something wrong. BH Green Panel - Addons - Addons Download Manager (upto here its OK) when I proceed it says Sorry, connection failed.
Please assist
K/Rgds
Supermario
VU+DUO with Blackhole in Flash
Hi Guys
Please assist
K/Rgds
Supermario
You can find an help here: http://www.vuplus-community.net/boa...-vu-duo-1-4-2-multiboot.1195/page-4#post-9247
