Black Hole Vu+ Duo v. 1.4.6 Multiboot
nice image, very good job. But new drivers and image 5.7 (so BH 1.4.6 too) still have problem with DTS pass through via SPDIF and HDMI (mkv movies 1080p)...
Thanks BH team for new image ! :thumbup: :notworthy:
Vu+ developer team - Too bad that you have not yet enabled SW DTS as the dreambox receivers,fix multimedia and improved picture quality on SD channels. I hope that you will not make a mistake just to enable that on new models because they would lose many users !
Thanks.
Good job. Nice image...
The font of the new skin has problems with the Spanish language.
For example, the channel is called: C+ FÚTBOL HD and the program: MÁS DEPORTE (HD)
Kisses from Spain.
Katia.
Thanks.
Kisses from Spain.
Katia.
It seems some letters are not present into used font.
You can solve this issue installing another skyn by Addons Manager.
Hi Guys
As mentioned above by grimm70 "will it work to just update the driver on the BH 1.4.5?"
I have the BH 1.4.5 already installed in flash, do I reinstall this new image 1.4.6 again in the flash which would overwrite the old one OR can I just update?
Thanks a lot to the BH team - As always, Great work Guys - Bravo
Supermario
If some of colleagues tried to put new drivers on BH 1.4.5 and if it work normal, please write here that.
