Black Hole Vu+ Duo v. 1.4.6 Multiboot
Hi jbond,,,!
Can U post/grap pic of your Reception Setting ,,,,,,The Admn Angelo is right most of the error @crash log is about rotor locking!
To grab the screen you can use the following command issued into a telnet session:
grab -p
The result is a screenshot.png into /tmp folder of your box :)
Hi jbond,,,!
Hi a911.
Can you more detailed with "Reception setting" ? I can grab the screen, but I don't know what screen.
Hi a911.
I think you must grab the "Tuner settings" (into Menu -> Settings -> Channel search -> Tuner setup or similar one - I don0t have the box avaiable at the moment).
I am attaching the two screenshot and the latest crash file made it when I grab the "tuner settings" screen. Thanks for yours patience to my problem.:)
Hi jbond,
1st
like 2know how many LNB your working with?
The 2 crashes U posted are not the same!!!
And those crashes when they happened, will U give more details!
2nd
The BH image , from my experience, may crash from the following: wrong skin, incompatible plugin, overloaded EPG...some times with EPG Autostart(setting for future dates) or may be illogical tuner setting, but never happened 2me .
Other wise its very stable and smooth!
Other members, here ,can offer what they think and share their experience, please !
Rgdz
a911
Have you tested with a clean image
no plugins and no Picon ? I see that you use Pauli plugin.
So clean image without adding.
For such problems it is desirable first to test with a clear image.
If you use SAT settings list .Try another.
Hi guys,
1. I have only 1(one) LNB
2. The crashes always happened when I am changing the channels
3.Yes, I use Pauli plugin, and default skin (I like it very much)
4. I use picons too.
I will try to reinstall the image without any plugins and picons.
For the last time annex the bottom crash file. Probably I have bad luck or I am not enough prepared technical. That is it. Again, thanks.
Hi, jbond!
I have 4 LNB's
Here is my settings f0r #1,,,have been using for long time and NO crash,,,,try it ....but U may have to change to none @DISEqC mode, since there is only one LNB used!
I Do not think picon@USB has anything to do with crash!
Please do as MX10 recommended and go for clean image!
Gdluck
a911
Hi, thanks for new image.
But I prefer Brio HD skin from 1.4.5. I downloaded and installed Brio HD in 1.4.6, but it's not the same.
Especially the EPG view when "Channel +" button is pressed. Instead of 16 channels on let side, and picture on right, picture is on top and 8 channels underneath. Why is it different, and how can it be changed? Also movie list is slightly different.
EDIT: Nevermind, looks like it was Brio STD-HD which I liked. I'll try that shortly.
