Black Hole Vu+ Duo v.2.0.6
Hi Guys Thanks for all your hard work with the latest image!
Im trying to update my brothers Duo to BH2.0.6 its currently on Dream elite black hole Enigma:2010-01-29master Image:Release 1.0.0 2010-06-05
its not seeing the update on the usb stick- I'm using the right image for Duo and the same method I've used the last few times to update my Solo2.
Is there something besides the normal flashing process I have to do to go from the old image to 2.0.6?
Thanks in advance!
First of all, you need to update Duo CFE to latest version and next reflash your image.
Many thanks for a great image... I just upgraded from 1.7.2, my first image upgrade, and it all went smoothly. Saving personal settings (personal backup or whatever it's called) made it all very easy. Lots of changes and new features since 1,7.2 and it all looks very good; and very stable so far. Thumbs up from me.
"You can use native Samsung Galaxy player by pressing *))) ] (allshare)"How can I activate this function in Duo ?
THKS
THKS
In black hole speed up 2 * blue button .....you have to enable coherence upnp renderer. In android settings Go into nearby devices and activate file sharing. Allow then coherence page getter if it pops up on your device.
One coherence page getter is in allowed list. Go to gallery press all share button. Select your vu plus device and watch the magic happen :)
