Black Hole Vu+ Duo v.2.0.6
hi
i have 2.0.6 but it have problems
1. some time when i started it for 10 minuete havent signal
2. some times when shout down the box reboted and started again
hi guys
I have the blackhole image 2.0.4 I want to keep updated with the updates 2.0.6 and so on is there a guide I can follow without having to redo all the settings again just update the image and leave the rest as it is thanks
Black Hole 2.0.6
What is new ?​
    • New Plugin Net Drive
    • New Coherence UPnP Renderer
    • New Coherence UPnP Server
    • Removed Dlna Djmount client Bh version
    • Removed Minidlna Bh version
    • Added Vu+ Dlna Browser (based on djmount)
    • Added Vu+ Minidlna server
    • Fix and Update MyTube plugin
    • Update lcd4linux
    • Update Openwebif
    • Update all dtt drivers
    • Update TranscodingSetup plugin
Vu+ Drivers:
    • 20130918
      - Fix transcoding problem(duo2)
    • - Fix vtuner problem(duo2, solo2)
    • - Support non bcma encrypted PCMWAV in media playback
      - Add missing entries in framerate_choices(duo2, solo2)
      - Support 4 vtuners(duo2, solo2)
      - Support transcoding in vtuner(duo2, solo2)
    • Fix 1080i problem (duo2)
    • Fix AC3 sound problem (duo2)
    • - Fix DTSHD downmix & passthrough
      - Support more than 4 tuners(vtuner) in duo2 and ultimo
      - Fix play/pause in solo2(when duo2's new remote control is used)
      - Fix Xcrypt card detection problem(duo2, solo2, uno, ultimo)
      - Support transcoding bitrate/framerate setup
      (solo2, 50K<bitrate<1M, Change is in effect in the subsequent connection )
Misc:
    • [dvbmediasink] support DDP patch.
    • Add curlftpfs
    • [wlan] added driver for Realtek 8188EU chipset
    • [mt7610u] Added D-Link DWA-171 Rev. B1
    • [wlan] Added new Realtek Driver - 8812A - 8821A who support AC standard
    • Update HbbTv
    • Add python packages: misc, shell, types
    • Update af9035 firmware.
    • Increase vtuner number in udev up to 4
    • TransCodingSetup : set defalut bitrate of SOLO2
    • TranscodingSetup : change bitrate range (solo2, 50k ~ 1M)
    • TranscodingSetup : add framerate settings (25k, 50k)
    • TranscodingSetup : add default button
    • TranscodingSetup : use notifiers for set change
    • AudioSelection : Dolby Digital downmix -> Dolby Digital / DTS downmix
    • ServiceInfo : crash fix.
    • Update languges Cs, Da, No, Ru, Sk, Sv
Howto Dlna Renderer:
Enable UpNP renderer in Black Hole Speed Up
Start Bubbleupnp, Devices, Renderers and choose duo2, solo2, solo or the box name available.
Then choose library choose a media and press play.
You will play your media to your box.
You can use native Samsung Galaxy player (video, gallery, media) by pressing *))) ] (allshare)
The image MUST be installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Black Hole 2.0.6
What is new ?​
    • Update lcd4linux
    • Update Openwebif
Vu+ Drivers:
    • 20130918
Misc:
    • Add curlftpfs
    • Update HbbTv
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
Merci pour cette nouvelle version
