Black Hole Vu+ Duo v.2.0.6
Only half the channels lock in rest show no signal. Back to 2.05 rev. B and everything fine with old settings.
So definately a problem with duo and 2.06
Check all your FTA channels from your bouquets. If they are all working well, it's not a problem of Duo and BH 2.0.6.
I did that before reverting back to 2.05 B
THERE WAS NOT SIGNAL so its an old transponder problem which happened on certain old images
hello
every time i run youtube a greenscreen pop up then restart of receptor, an absent problem in the previous version !
Thanks for a great image Bh Team
after upgrading from 2.0.4 I can't seem to get Airplayer working. Has anyone else had this problem or able to offer any advice?
I don`t know exactly but i heard, that you must make a donation for the airplay plugin .
Thanks for the reply.
I have purchased a premium key and have been using the plugin on previous BH versions for about a year no problem, but I can't seem to get it working since upgrading to 2.0.6 rev c.
Very weird
Very weird
Please, report which previous version. Because 2.0.5 was released on July 28, 2013. It will help to solve a problem.
