Black Hole Vu+ Duo v.2.0.7.1
If you have BH 2.0.7 its quite strange that you can not install.
Check your network configuration.
If not help
Attempts to reinstall BH 2.0.7 and immediately update.
All working, no network problem ... so ... i will reinstall with my USB key and not online but it's really stange no ?
hi
i have the acctual image 2.0.7 and i want update to the new version here !
but i cant update it says no update available !
can you give a little how to how wo update online ?
thx for great image
hi
thx for great image
Flash image 2.0.7.1 then online update... For some reason 2.0.7 doesn't like to update on duo to 2.0.7.2
Hello,
I have vuduo BH 2.0.6. I wonder if in version 2.0.7.1 there is some kind of wake-up plugin that can auto start box from standby elle deep sleep. For example, at 08:00.
Thanks
Hello,
Thanks
Not that I'm aware of my friend. Only a sleep timer. Maybe you could add a request thread in BH general for future release?
Hello.
Thanks for your reply. Actually, my TV has not wake-up function. So with a wake-up plugin BH would also, via HDMI-cec, at the same time start both box and TV. I think many Bh owners would like to have it.
