Black Hole Vu+ Duo v.2.0.7.1
HI PAOLINO
THIS DISPLAY IMAGE WHAT YOU PUT HERE IS OLD VER. IMAGE
PLEASE TRY BEFOR YOU ANSER
THE NEW BLACKHOLE IMAGE ITS NO HDMI OUTPUT ONLY DVI
See here
See here
DVI2.jpg DVI1.jpg ="paolino, post: 117906, member: 20777"]@
Please, at first, Don't Shout By Writting In Capitals.
The picture I posted is 4 hours old, I'm using Army Touch Skin.
I switched to Default Skin.
PS: Do you have some visualisations problems on your HDMI TV/Monitor? DVI is same like HDMI (video), but without audio signal.
HI PAOLINO
Are you using image Black Hole v.2.0.7.1 and box vu+duo.
dvi2-jpg.13750
Because when I using image Black Hole v.2.0.5 and box vu+duo . get the only option HDMI ok
When used the Black Hole v.2.0.7.1 and box vu+duo. get the only option DVI
dvi1-jpg.13749
="paolino
Hi,
I have also the same issue about the HDMI missing in AVVideo settings with my new BH2.0.7.1.
What can I do for resolving this issue please as I have only SCART, DVI, YPrPb as choice.
Thanks,
Could someone other moderator (Matrix or Shiro) help us on this issue? The HDMI ouput image is the best one.
Thanks a lot!!!
HDMI ITS A NEW OUTPUT .... And works on special wizard
DVI ITS OLD OUTPUT ... And works on its own processor
VU+DUO Director picture and sound .
It seems that the images BH 2.7.1 carry Kernal very old
dvi-out-jpg.13783
dvi-out-jpg.13783
To be honest, who cares! As long as it still works
dvi-out-jpg.13783
Are you crazy? I think YES.
On Vu+ boxes (ALL MODELS) there is no DVI port (phisically) but ONLY HDMI.
Both DVI and HDMI are DIGITAL ports.
On software side (Enigma2) the selection between DVI or HDMI is ininfluent.
I'll repeat one more tme: KERNEL VERSION IS UPDATED BY MANUFACTURER AND IS DIRECTED RELATED TO DRIVER VERSION. HDMI/DVI OPTIONS IN THE Enigma2 GUI IT'S ONLY A LABEL AND MEAN THE SAME VIDEO OUTPUT: THE DIGITAL ONE.
More polemic posts about these things will NOT BE TOLERATED MORE.
I used to be able to do an online update but the last few updates I`ve struggled to do it I`ve had to do via usb. Why will the online update via addons not work for me when I press on `Online Blackhole image update` I`m on BH version 2.0.6c I just wanted to do a quick online update. When I do it says Software update Done Installed or upgraded 0 packages
Whats going wrong??
Whats going wrong??
Because new drivers you need usb update to 2.0.7.1. Then online update to 2.0.7.3
You've reached the last revision of the 2.0.6 series
Oufffff, the HDMI for AV Video is back with the last live update of my BH 2.0.7.2 to BH 2.0.7.3
Thanks to the BH team for this accomplishment!!
The online update via addons not work for me when I press on `Online Blackhole image update` I`m on BH version 2.0.7.1. When I do it says Software update Done Installed or upgraded 0 packages. And, I can't download MyMetrix-OpenStore from addons download manager. What happen with my v+ duo?
