Black Hole Vu+ Duo v.2.0.7.1
The online update via addons not work for me when I press on `Online Blackhole image update` I`m on BH version 2.0.7.1. When I do it says Software update Done Installed or upgraded 0 packages. And, I can't download MyMetrix-OpenStore from addons download manager. What happen with my v+ duo?
Evidently you have a network problem, check it.
Because new drivers you need usb update to 2.0.7.1. Then online update to 2.0.7.3
You've reached the last revision of the 2.0.6 series
yes your correct I did it last night and it worked online updated from 2.0.7.1 to 2.0.7.3 OK
thanks
some time when i shut down my vu duo is restarting ?
i tested with bh 2.07.3 & 2.0.5 & 2.06
what is problem?
I'm afraid.
I installed Blackhole 2.0.7.1 and everything is working fantastic except when there is a crash or a manual reboot the Gateway Primary DNS of 192.168.1.254 defaults back to 0.0.0.0
I've attached a crash log. I'd appreciate any help in getting the DNS to "stick"!
I've done an online upgrade to 2.0.7.3. That seems to have fixed the DNS problem. Thanks.
It seems the issue is due to the plugin Open Uitzending Gemist, try to uninstall it.
what is problem?
I uninstalled Open Uitzending Gemist and rebooted but the Primary DNS setting still resets to 0.0.0.0 Blackhole 2.0.7.3 build image. Any more thoughts?
with black hole 2.05 0r 2.06 or 2.0.7.x i have problem
sometime when i turn of vu it is restarting and Again becomes activated
i instaled 2.0.3 and a have not problem . .
any idea?
