Black Hole Vu+ Duo2 v.2.0.6
Hello there! Thank You for pretty good image. I am newbe here but already like BH image.
I have installed BH 2.0.6 and it crashed (green screen) after channel scan, when I trying select any channel first time.
Where I can post crash log or should I get some info from com-port?
Thank You!
Thank You!
You can post it here
Thank You! Seems there.
[AutoRes] service changed
  File "/usr/lib/enigma2/python/Navigation.py", line 43, in dispatchEvent
    x(i)
  File "/usr/lib/enigma2/python/Components/ServiceEventTracker.py", line 38, in event
    func[2]()
  File "/usr/lib/enigma2/python/Blackhole/BhEI.py", line 142, in __start
  File "/usr/lib/enigma2/python/Tools/Transponder.py", line 39, in ConvertToHumanReadable
    eDVBFrontendParametersSatellite.System_DVB_S2 : "DVB-S2"}[tp["system"]]
KeyError: -1
(PyObject_CallObject(<bound method Navigation.dispatchEvent of <Navigation.Navigation instance at 0x1268418>>,(5,)) failed)
    x(i)
    func[2]()
KeyError: -1
I suggest to report it to Vu+ Dev Team (www.vuplus.com)
is there any suggestion to solve the green page problem.
I did again a reflash but the problem is still there.
how can i be sure about a clean image install and nothing left from previous version??
i think something is wrong with the image or the driver !!! and can not delete them properly.
Hello there. I living in Belgium (dutch part) for 30 years now but I was born in Germany. After 10 years without sat, i have now also a VU+ Duo2 receiver. So sorry about my writing because that's not perfect. :)
I have installed Black Hole 2.0.6 on my box and i am very happy with this. First of all i will thank everyone for the good work. Perhaps i have some questions later but for now and after a few days using the Black Hole image, i have to say one thing: thank you very much for this beautiful image and many thanks for all your work.
Rudy.
Hi.
I have install BH 2.0.6. But under setting satelite sirius 4,8 are missing. How can i put this satelite in setting??
Hi.
Hello, but this satellite for now is Astra 4A/SES 5 (4.9E) - just last year, AFAIK, and orbital position also was changed.
So, please look over your salellites.xml file and try to find with search.
Good luck!
Thank You!
The same problem!
Hi.
It seems that many do not know.
You can make and download satellites.xml for your needs on this website.
http://satellites-xml.eu/
after download
upload (FTP) new satellites.xml to / etc / tuxbox folder.
Restart enigma2
For performance it is best to make satellites.xml only for used satellites.
For motor users my satellites.xml from 45e to 45 W in my ZIP
Pay attention
If you're using ready-made SAT lists
In this case your satellites.xml will be replaced.
Hi all! Hi Matrix! Good to meet you again!!!
A Solo2 BH 2.0.6 image doubt: does it NO work SPIDF optical audio output? I've tested with 2 working optical fiber cable, with a digital working soundbar, a digital working amplifier, etc. and I cannot get (even changing Downmix to off, ofcourse)...
does anybody know why? Thnx im advance! Cheers!
I do not use the solo2 SPIDF
I can not believe if it does not work.
You have test audio option (audio button)?
I think it must work
Maybe other people know.
Welcome to the forum
I'm glad to see familiar people.
Sorry me Matrix, I was wrong... yes, it works. But ONLY in channels with Dolby Digital audio streams... It doesn't work in channels with Dolby Digital + audio streams.... Like Spanish TVE HD or C+ Accion HD (spanish ones also).
So maybe it's a 'driver' issue?
Cheers!
Cheers!
I believe that you will get a better info from the Spanish users.
We have also Spanish section. Maybe you can ask also there.
