Black Hole Vu+ Duo2 v.2.0.6
Hi, Had similar problem, Tried to find something from the VUs manual, and the RAM went upto 98% but after
reaboating it went down to 25%.
You have to understand, that RAM is for to be used. Not to be free. The system loads RAM as much as possible to be faster. And not to go around to continue to load and unload necessary data into it.
Thnx Eragon, I saw this thread but I have no problem with DD+ throught HDMI... for me it works so well... and it's not an 'spanish' issue or something like that has to be solved just in Spain... is the way the audio drivers throw the DD+ to the SPDIF optical audio output...
Cheers.
I think it's solved with new Drivers VU+ 23-10-2013
Regards.
I can confirm that in a vu+ solo2 now, with today drivers, it's possible to get out through spdif optical audio output (and downmix off) the Dolby Digital + audio from some spanish channels. Until today it was only possible through HDMI and downmix On. Cheers!
How to play them files? I mean, I have a movie and it's splitted to 56 m2ts files in a "Stream" folder. I can play them separately but how to play them all together (merge) to watch a full movie?
You can add all files into a playlist with Media Player
There is a lot of unnecessary files (for Blu ray) in the "Stream" folder. The most wanted file is one 26.7GB. The receiver can play that file but I have a problem with the subtitles. The system doesn't see the .srt file and the subtitles don't display.
Other movies (AVI, MKV, MP4) do cooperate with .srt subtitles with no problem. What do I wrong?
