Black Hole Vu+ Duo2 v.2.0.6
Thnx Eragon, I saw this thread but I have no problem with DD+ throught HDMI... for me it works so well... and it's not an 'spanish' issue or something like that has to be solved just in Spain... is the way the audio drivers throw the DD+ to the SPDIF optical audio output...
Cheers.
Of course, but only few outside Spain could effectively help you (and even notice this problem) because at least in my country we don't have subscribed channels with DD+ to test with.
You in Spain are luckier!;)
I can test but I cannot solve it... maybe vu plus guys should? THnx
Does the first post always contain the latest revision, rev.C? Or where do I find it?
I know there is a separate download site but I cannot remember the address at the moment...
Please help me =)
Please help me =)
Download 2.0.6 m8. Rev c is online update
Cheers guys.
Only one issue-can someone to explain for why my vu duo 2.0.6c is using 96% of ram.Is that normal(Considering the huge 2gb ram inside duo2)?
Cheers guys.
Just do a restart m8 it goes back down to under 30 then. Don't know why it creeps up. Mine seems to do it if I've been using 1channel and icefilms. It must store some data in the ram to increase speed of using plugins etc so no harm
Cheers
I just had installed 7 plugins and ram went down to 93%.
After couple reboot with went down to 27% ,couple skins installed -back to 92%.
Its no harm mate its only random access memory... Like I said to improve performance. When you switch of or reboot its wiped. And if it needs it it'll wipe over info that's not used
I have little bluray collection and want to rip it out and put on the hdd.Will duo2 be able to read bluray iso ?
Hi!
Am I only who has problem with Transcoding on very last BH (2.0.6c) on Duo2? Normal streaming works perfectly fine, but Transcoding is not. Well, VLC don’t play at all. Android app tyres to play - beeps 1 seconds sound and then crash and that’s it. BH 2.0.5 worked perfectly fine, so no blame on FW, port routing etc. Transcoding settings are: BR: 2100000, F:30000.
Tuner: Vuplus DVB-T NIM(CXD1978) (DVB-T)
