Black Hole Vu+ Solo 2.1.7
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
    • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
    • New skin MX i6p By Matrix10
    • Vu+ drivers 20150623
      - Fix tuning problem(AVL6211, duo2, solose)
      - Improve vtuner(satip support)
      - Fix scrambling bit in recording
      - Improve transcoding
    • Xbmc Support 576/720/1080 resolution
    • Updated Vuplus-Blindscan
    • Updated HbbTv
    • Updated WebManual
    • Added Sat>Ip Client
    • Included UiPositionSetup
    • Removed MeoBoot
    • Added OpenMultiBoot
    • Updated Lcd4Linux
    • Updated MediaTree (usb tuners drivers)
    • Fixed random socket error
    • [ScanSetup] fixed error on complete scan with T2 tuners
    • [ScanSetup] fixed TT3L10 automatic scan problem
    • [unicable] support JESS(EN50607) and update unicable.xml
    • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Plese help if possible. Last friday I accessed Blackhole speed up and disabled weather. when it re-booted all pay channels missing. I left it overnight because i have auto bouquets set for 0600 hrs and thought it woud reset. still off except terrestrial.
I noticed the flag about 2.1.7 and downloaded it to usb. Flash went through the process, no other devices connected. After re-boot it "started" then a new blackhole icon came up on a black background then it went to "Vu+solo2" and remained blank, No response to any remote button. I tried a different stick same reult. Two months ago I had to re flash 2.1.6 which worked fine so I used that stick knowing the file was good, same result black screen, dead box.
If it's a clone, it's normal ....
Thanks for the prompt reply. I,ve had the box for 7 months hassle free. It crashed once before when I exited blackhole speed up and had to be flashed 2.1.6. All went smoothly. I bought from a source that has always replied within an hour for any tech. support and was I able to log in to tech support on his site, but has gone AWOL since Friday, no reply email not deliverable and a new site which directs to links only.
How can I check if box is genuine? If genuine is there anything you recommend I try.
Failing that if there is someone in UK willing to accept the box by mail I would happily pay for repair to get my lovely box well again.
http://www.vuplus-community.net/board/threads/howto-recognize-a-solo-duo-clone.12815/
Where I can download Army Trancparency HD skin for this image? Why this skin is not available on BH feed anymore?
Thank you))
Hello, I installed 2.1.7 on my VUPLUS blackhole solo, and not let me install plugins for install emus or through telnet, or using the installed IPK blackhole, I get an error and does not install
I could do to install it?
mi vu+ solo is genuine, not clone
Thanks and sorry for my bad english
NO Discussion about Emus or cams is Allowed here. Please read the Board Rules: http://www.vuplus-community.net/rules.html
Best Regards
Pyromon
ok sorry, I've solved. But I can not install packages of plugins to add functionality to the image, installation fails me. There are some plugins package that works well with this image?
I have solved the plugins, anyone know how to get out in the epg panel image channel being viewed, as in the pictures at the beginning of the post? do not leave me to my these images
@snako79
This is your 1st and last warning, please read the rules of this board, that you agreed to when you signed up.
Next time you will be banned.
